In-wall wire
gwh
Getting ready to by some in-wall wire.
This looks like a pretty good deal.
If anyone knows of a better deal let me know.
I'll be putting 225w per.
G
link
G
link
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
g,
If you are actually going to use it in-wall, then I'd get this.
Since you have LSi's, and they are biwireable/biampable, it will serve you better in the long run.
It does look like a good price on it too.
Have a good one. Sorry about the 9's.
ZachTschüss
Zach -
What the heck, its only about $15 more for double the wire, I'll check it out.
That sucks on the 9s, but the seller you recommended replied promptly, and is going to help me out with the damage claim.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
The only difference I see in the 14/4 is that it is yellow(not the most attractive). You could always get to runs of the white 14/2, but that might be more of a hassle. I think you can get the 14/4 to where it is paintable.
I'm glad he is willing to help you with the 9's. There was a mixup with my 7's as well, but he was very willing to work with me to get it all straightened out at his expense.
I'll be in OK in a couple of weeks. I think I'm going to visit Dennis Gardner (only 45 min from my parents) to listen to his SDA's.
ZachTschüss
Zach -
what's it matter the color of the speaker wire? It'll be inwall!Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
I guess you are right. If you use a wall plate connection, then you won't ever see it. I just try to keep as few connections as possible between source and speaker. If the speakers are not inwall or onwall, then there will be a little speaker wire showing some places. If it showed in my house, I'd just paint over it.Tschüss
Zach
