B&O CX100 crossover enigma
xschop
I'm going to start modding these for another near-field setup and want to experiment with padding the tweeter with a 0.5 or 1.0 ohm resistor.
Just getting opinions, where would I insert the resistor into the diagram here (found off the net)
Wish there were a schematic diagram to make things easier to decipher lol.
I'm thinking you put the resistor between the 6.8uf capacitor and the negative terminal of the binding post.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Ill give it a go. I've got some spare Mills 1.0 ohm and Clarity PXs just showed up.... Might well so wires while I got it all apart. The way the rear panel is, I can mount it externally and easily test different resistors...
Don't take experimental gene therapies from known eugenicists. -
Piggy-backing an Xover makes things ALOT easier for sure. Not @VR3 fancy, but'll do for testing.... Guess I better listen without resistor first and burn some Clarity's in...
While waiting on the new Wu-rubbers, I've started dissecting the midrange for uber mods...
Will have to shorten a set of MW65xx plugs, but they drop right in with B&O pole-piece ODs being 0.997, same as Polk🙂
Fiber backed neoprene rubber to ensure a good seal around the thin metal baffles and extra damping to boot with the Polyurethane coating on the frames. They'll get a layer of black latex after full cure....
Here we lost a lot of weight from a very thick and coated paper dust cap. I gave them one light coat of latex doping compound...
B&O upped their game along time ago...
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
The alloy housings are built solid quality, but have a slight ring being only 0.180" thick.
The butyl mat quiets them down very good where only thumps are heard when tapping on all sides....
Is that tweeter magnet shifted or is this just due to camera perspective?My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
Camera. They even have damn good glue lolDon't take experimental gene therapies from known eugenicists.
Whoa! That is one major bored out pole piece there! Is that a chunk of open cell foam? Does the hole go all the way through in the back or is it an acoustically damped chamber? I see they even rounded the upper edge of the pole piece presumably to diffuse the reflections there.George / NJ
iFi nano iDSD DAC
iPurifier3
Open-cell within a cast hyperboloid and a foamed backchamber. B&O did all the XS-modding already lol.
They left at least one thing I can mod.
The consensus is that plastic diffuser needs to be cut off. I'll machine some billet bezels for these sans diffuser.Don't take experimental gene therapies from known eugenicists. -
Pretty small drivers. Phase plugs will result in about 8 to 10% reduction in Sd in this case. Are the replacement surrounds butyl or the original foam?George / NJ
iFi nano iDSD DAC
iPurifier3
Butyl. Hopefully that helps. But not plugging the lower woofer as I think this is technically a 2.5 way designDon't take experimental gene therapies from known eugenicists.
It's a pretty crazy crossover. I found this, which doesn't exactly clear things up totally, at least not for me (lol). This person seems to think the upper woofer only receives the lowest Hz signal.
George / NJ
iFi nano iDSD DAC
iPurifier3
Do you think they flipped phase of the tweeter because of 6.8uf on NEG side?
The other enigma is the lower woofer pole-piece is vented, the top "midrange" is not.Don't take experimental gene therapies from known eugenicists. -
If what the guy on Audiocircle said is correct, the upper one is the woofer and the lower one is the midwoofer. That would make sense? because you would have more need of a vent on a midrange?George / NJ
iFi nano iDSD DAC
iPurifier3
I would normally assume vented pole piece for woofer, if the vent was on midrange, there'd be coloration by bass waves affecting the midrange cone.
They both have 5.1 DCRDon't take experimental gene therapies from known eugenicists. -
I think that the small inductor and the large inductor are in series for the top woofer and inductances in series add and the larger the inductance the lower in Hz is the low pass filter. So I think I agree with the Audiocircle guy that the top one is the woofer that receives only low frequencies. Would be good to measure the inductances of the two coils.
For the tweeter high pass circuit, I don't think it matters whether or not the capacitor is on the positive wire or the negative wire, just that it is in series with the tweeter.George / NJ
iFi nano iDSD DAC
iPurifier3
Ah, Ok I see what you/they are saying. The midrange (Lower MW) relies on roll-off after the small inductor. So I guess B&O got more performance from the midrange by adding a vent for pistonic speed.
Also makes sense that they had the midrange angled slightly upward as these set on a credenza or desk.
Maybe I'll just run these as woofers as phase-plugged mids and run the original midrange as a vented woofer? What's nice is I can also flip the cabs and have a listen too while on PC rig.Don't take experimental gene therapies from known eugenicists. -
As for tweeter, wouldn't this have made more sense?
Question: Why not measure the DCR of the coils and build a new crossover, this one seems really simple. Correct me if I'm wrong, but the tweeter has a first order high pass, and then one of the woofers is being run full range and naturally rolls off with the other having a first order low pass and acting as a bass driver?
Super simple design, and I mean you can use natural roll off and make it sound nice (the 1992 Monitors from Polk did this) but why not go the extra mile?My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Calling @westmassguy lol. Strange looking crossover scheme here. Even trumps early Polk production Hail-Marys.
I'll pull inductor coils tomorrow and get DCR and mH'sDon't take experimental gene therapies from known eugenicists. -
Ill' pull inductor coils tomorrow and get DCR and mH's
Do you use the kelvin sense lead method to measure DCR? https://www.debassociates.com/blog/inductor-dcr-measurement/My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
I just use my trusty Wu-Bay LCR digital meter with loop leads.Don't take experimental gene therapies from known eugenicists.
Wu-bay? That's a new one, I'll group that one with "Chinazon"My gear:
- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Whether it be brass binding posts or DIY kits for serial-passaged forced evolutionary chimeraviruses, the Wu-bay has it.Don't take experimental gene therapies from known eugenicists.
One would think so but I've learned to never underestimate the Krauts because there is usually a method to their madness.
JAT - If swapping drivers and adding phase plug lowers their sPL at all you might try lowering the DCR of the inductor(s).George / NJ
iFi nano iDSD DAC
iPurifier3
These little jewels are hefty for their dimensions...
Old cap...
New cap (Same Clarity Cap now residing on 5B tweeter circuit)...
Factory small coil....
Factory large trans coil....
Factory gaskets not positioned/sealed well. Don't look to have been opened, but stuffing is different that other net-pics I've seen...
There are sealed chambers for each driver? Or are those just open braces? Is there a bass reflex port?George / NJ
iFi nano iDSD DAC
iPurifier3
No port. All open chambers (3rd pic down from enclosure dampening pics).
Factory tweeter foams about rotted, shrunk. Glad I got extra wool tweeter pads from @VR3. Trimmed edges and 2.5" center hole and they fit perfect. Look darn sweet too...
Here's the lower midrange angle... Looks to be 10°
Port it and add a power port 😂
Seriously though, I think I already mentioned this but replace the ferrofluid in the tweeter if there was any.
Or... if you want to get ballsy, add some anyways and see what happens 🤷♂️My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
There was no dried FF on the coils. Will simply swap out the foam plug for lamb's wool.
Dual Polyurethane/Latex layers are cured and baskets no longer ring when thumped...
Before I install new butyl surrounds, the midranges' inner frames will get some foam.🙂Don't take experimental gene therapies from known eugenicists.
