Polk L800 Discounted.
Irrenhaus
Irrenhaus Posts: 1,102
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    F1nut Posts: 51,776
    40% off list is a very good deal.
    heiney9 Posts: 25,432
    Yes, good deal. The promo they ran last time for the 50th anniversary was about 40% off list. That's when I bought my L600's. I realize these are refurbs, but you still get a Polk warranty. I doubt you'll ever find them cheaper until they are discontinued.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,771
    Has/does Polk release the number of L800's sold?
    The curious like to know.
    Harry / Marietta GA
  • TroyD
    TroyD Posts: 13,124
    On the new market....you'd be hard pressed to bet better sound for the money. I absolutely love the L800's.....
    However, if you are expecting an updated vintage SDA......it just isn't. It's a totally different speaker.
  • Emlyn
    Emlyn Posts: 4,710
    I'm still curious why some of the major online sellers discontinued selling the L800s but others still list them. It's possible that the refurbs are new in box. But, I would call them to ensure they have a left and a right matched pair.
    pitdogg2 Posts: 27,050
    ABSOLUTELY agree.
    msg Posts: 10,452
    And the stories of people reporting back saying sellers respond: "A right and a left? Who ever heard of such a thing - that's prePOSterous! You get what you get!"
  • ChrisD06
    ChrisD06 Posts: 927
    ABSOLUTELY agree.
    I could be entirely wrong here, but...
    Couldn't you just disassemble the speaker and swap the midranges and tweeters around? Obviously you'd risk damaging something but if it's 40% off!!!
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    nooshinjohn Posts: 25,926
    ChrisD06 wrote: »
    ABSOLUTELY agree.
    The difference is not in the drivers… it’s in the crossovers
  • ChrisD06
    ChrisD06 Posts: 927
    ChrisD06 wrote: »
    ABSOLUTELY agree.
    Sorry. In my head it made sense because the wires would still be attached to the drivers, so you'd essentially just swap the wiring around.
    The point still stands, couldn't you just change the wiring or are the crossovers literally designed in such a way to have a left and right channel. The original SDAs used the same crossover and just changes the side of the dimensional array wiring and the side of the stereo array wiring around. Could you not just do the exact same with the L800?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    Try that with a 2.3tl....
  • ChrisD06
    ChrisD06 Posts: 927
    Ah yeah , that's an exception. Either way you get what I mean, the speakers are symmetrical, in theory you can just swap the wiring.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    F1nut Posts: 51,776
    The crossovers inside each L800 cabinet are made up of 3 separate boards.
    I have a set of boards here... there is only one that they sent me. is it possible they have changed the design down to just one board? I would also love to see a cutaway of the cabinets...
    F1nut Posts: 51,776
    Sorry, it's two separate boards. One main and one small. The main board has separate sections for the stereo and SDA circuits.
  • ChrisD06
    ChrisD06 Posts: 927
    That's one beefy crossover. Has anyone gone through and rebuilt them with Mills and ClarityCap or is that just not needed with them? Never heard any Legends.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • bcwsrt
    bcwsrt Posts: 2,411
    Looks to me like that would get expensive quick. I’m not sure why you’d buy a brand new, current production speaker and turn around and rebuild the crossovers in them. Probably bought the wrong speakers, if that’s the case.
    Brian
  • ChrisD06
    ChrisD06 Posts: 927
    bcwsrt wrote: »
    I don't disagree with any of your points, just curious if some madlad, went and did it.
    I am curious on your take about this: I see so many people talking about rebuilding crossovers to improve sound, why wouldn't it apply to new speakers?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    msg Posts: 10,452
    I agree - I always want to see cabinet cutaways of every speaker. I wish everyone showed this.
    Why do you have a set of boards? Was this advance order planning to upgrade the components and keep a stock set as well?
    msg Posts: 10,452
    bcwsrt wrote: »
    I'd do it just for the component upgrades. I still think it would be an improvement.
    I wonder what other mods would be beneficial.
    (annnd 3... 2... 1... @F1nut slaps @msg upside the head as a reminder for an ever-pending project that shall not be named, but rhymes with shoe point tree)
  • bcwsrt
    bcwsrt Posts: 2,411
    ChrisD06 wrote: »
    bcwsrt wrote: »
    Usually (almost always?), the reason for doing it is to replace 30 year-old electrolytic capacitors with better performing film capacitors.
    I suppose the same thing would apply to new speakers if you wanted to eek the last bit out of them by going to some higher-end caps, just seems like your money might be better spent on higher-end speakers to begin with.
    Brian
  • ChrisD06
    ChrisD06 Posts: 927
    bcwsrt wrote: »
    ChrisD06 wrote: »
    bcwsrt wrote: »
    Gotcha, thanks for the explanation!
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    F1nut Posts: 51,776
    As one can see most of the caps are MPT and MET with the larger values being electrolytic. Still, none of those are higher end caps, so improvements can definitely be had. Would it be bloody expensive? You bet! Upgrading all those resistors would net sonic improvements as well.
    You'd be surprised at what components are in very expensive speakers. More than likely what you're seeing on the L800 boards.
  • ChrisD06
    ChrisD06 Posts: 927
    You know I'm honestly shocked in a $4500 pair of speakers, the crossovers aren't higher end.
    Then again, they look like 4th order, and I cannot even begin to fathom the cost per crossover, it's probably over a thousand, correct me if I'm wrong.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • bcwsrt
    bcwsrt Posts: 2,411
    I had ~$200 just in 3 caps and 1 resistor per crossover in my 15s. Those L800 have to have near 10x those numbers (I'm not counting Lol).
    Brian
  • ChrisD06
    ChrisD06 Posts: 927
    edited July 2023
    bcwsrt wrote: »
    Dear God...
    You know, it makes sense that Polk would use a cheaper crossover considering how expensive quality parts are for them. They have a budget to work with and would you rather them use a cheaper XO or cheaper drivers and/or cabinet?
    I was going to rebuild my RT3000p crossovers... decided not to. Why? $450 for both. I can't afford that.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • chrispyfur
    chrispyfur Posts: 170
    Certainly helps when you're buying them wholesale
    audioluvr Posts: 5,915
    ChrisD06 wrote: »
    Yes you did. Go up one post. ;)
  • TroyD
    TroyD Posts: 13,124
    When you are building to a price point....it just is what it is.
    ChrisD06 wrote: »
    Well, in the high end realm.....the L800 is on the budget end of the spectrum and every company builds to a price point.
    I suspect that upgrading the crossovers could very well end up costing more than the price of the speaker if youwere so inclined....I've considered it but more than likely I'll move these down the road sooner or later....
    VR3 Posts: 29,428
    To use Uber quality like cmr, path audio, all air core inductors.... You would have to go external and the cost would be astronomical
    To use like csa, mox and a mix of air core and iron core would also be very expensive but stay internal.
    We modified the l200 and the difference was really noticeable through cell phone vids.
    Far more definition through it the spectrum. We changed several iron core inductors in series to the midrange which made a tremendous difference
