MagniFi Mini Hard Reset
Does anyone know kow to to a hard reset for this sound bar? I know how to reset the wifi but wondering if there is a way to do a system reset. Everything works fine up until I set up Google home. No no sound coming out of the speakers. Tried everything with no success.
  • mpedigo1
    If you hold the WIFI reset button down beyond the 8 seconds which will reset the WIFI (think it is one beep) until you hear three lower pitch beeps and see the front red LED start to flash...think that will do the job.
  • martwil
    martwil Posts: 2
    I have the same problem. Also totally no sound after setting up Google Home. After the WiFi reset i also not hear a beep! I have tried everything. I see that i have a connection with the TV or with bluetooth from my mobile. But no sound. I can not imagine that i am the only one with this problem!
  • sidders
    sidders Posts: 1
    Hard reset - Unplug the power cable on the back, wait about 10 seconds, then reconnect power, turn on, and reset your source.
