Mostly Preamp Tubes
snow
For sale are a few tubes mostly preamp tubes. The tester I used for these tubes test tubes at a lower percentage then most testers I have used in the past so they will likely be better then they show in any pictures. I have been out of the audio game for a while but recently came across these and thought I would give you guys and gals a shot at these. Most everyone who has been here for years will remember me and can vouch for my honesty.
In any case all tubes or anything else I sell comes with a your happy or your money back policy no questions asked or explanations needed, simply return what you bought and receive a full refund including shipping both ways.
Pictures of test results for any and all tubes upon request. These all test minimum good on my B&K Model 600 tube tester. Also please check the club house for a tube give away.
Shipping will be via USPS priority flat rate box small medium or large.
1. RCA 5751/12AX7 3 mica Black Plate Tubes-9- $25.00 each or $45.00 for a pair + shipping
2. IEC Mullard 12AX7A Tubes-2- $40.00 each or $70.00 for the pair + shipping
3. IEC Mullard 12AX7 tube-1-$40.00 + shipping
4. GE 5 star 3 mica 5751/12AX7 tubes-2-$20.00 Each or $35.00 + shipping for the pair
5. GE 12AX7 tube grey plates halo getter-1-$10.00 + shipping
6. Tung-Sol JTL 5751/12AX7 tubes grey plate halo getter-4- $20.00 each or $75.00 for the quad + shipping
7. GE 12AY7 D getter tubes-4-$20.00 each or $75.00 for the quad + shipping
8.Raytheon CK 5814A 3 Mica Tube Pair $30.00 + shipping
9.Raytheon CK 5751/12AX7 Tube-1-$25.00 + shipping
10.GE 12AX7 tube grey plates halo getter-$10.00
11.IEC Mullard 12AU7 Tube-1- $25.00 + shipping
12.RCA Clear Top 12AU7 Tube-1- $10.00 + shipping
13.RCA 5879 Tube Pair $50.00 + shipping
14.Mullard IEC 6L6GC Tube Pair halo getter-$100.00 + shipping
15. Raytheon 12AT7 WA 3 mica Tube-1-$10.00 + shipping
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
@kevhed72 Grab the 5751s quick! Your Joule will be happy.
Sir Ill take the 2 pairs of 5751s....
Could you post a picture of these Raytheons so I can see the tube structure?Raytheon CK 5814A 3 Mica Tube Pair $30.00 + shipping
Sure will post them in a few.Could you post a picture of these Raytheons so I can see the tube structure?Raytheon CK 5814A 3 Mica Tube Pair $30.00 + shipping
Regards Snow
Interested in #2 Mullard 12AX7A pair … Can you share any history about these? Past testing or microphonics?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Ok here a few pics first the 5751 pair then the 12AU7 and the 12AT7 last.
Not much history to re tell here are a few pics of the test results, these have not been listened to for microphonics they were pulled from an old Heathkit signal generator so likely seen little use and the test results reflect this they both tests as NOS tubes do on my tester they were both made in Backburn and have the same dates, and both tubes test very evenly on both sides and between tubes, of course if you get these and want to return then for microphonics or any other reason I will happily do so.
Sorry I mistyped that the first picture is of a 5814A/12AU7 pair the second pic is a single 5651/12AX7 tube the third is a 12AT7 tube.
Regards SnowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Now I'm very interested in ^^^ . . .
Any info you can provide on the
#4. GE 5 star 3 mica 5751/12AX7 tubes-2-$20.00 Each or $35.00 + shipping for the pairAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Not much to tell here. For some reason I can only locate one of them no idea where the second tube is I remember testing both of them one had one of the stars wiped but the other tube had all 5 anyways here are a few pics of the tube I can find and test pictures.
I did find two more RCA 5751/12AX7 tubes these are Command labeled with halo getters they both test above minimum good $20.00 each or $35.00 for the pair + shipping here are a few pics
I'll take these:
- two more RCA 5751/12AX7 tubes these are Command labeled
Juan -
Snow,
sent you a PM with request for some of your other RCA 5751 tubes as well.
Juan -
Thanks Juan your tubes have been set aside.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Updated list all RCA 5751 tubes are spoken for the Tung-Sol 5751 quad is sold.
1. RCA 5751/12AX7 3 mica Black Plate Tubes-9- $25.00 each or $45.00 for a pair + shipping- SOLD
4. GE 5 star 3 mica 5751/12AX7 tube-1-$20.00 + shipping
6. Tung-Sol JTL 5751/12AX7 tubes grey plate halo getter-4- $20.00 each or $75.00 for the quad + shipping-SOLD
Two pairs of the RCA 5751tubes have been set aside for you.
Did you locate the other tube?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
No it has vanished.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Did you check your sofa?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Did you check your sofa?
No because I was not near the sofa while testing or taking pictures.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
I'll take the Mullards After your generous karma drawing, bc the Mullards and karma can be shipped together to my crib
Feeling lucky!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Snow I will take #11 and #12 being the IEC Mullard 12AU7 off your hands, along with the RCA Clear Top 12AU7 ThanksHome Theater
Feeling lucky!
You may get lucky and win the Karma but sorry the Mullard pair have sold, I do have a Mullard single 12AX7 that you can buy if you wish. It was made in the Blackburn factory in 1961 and tests as strong as any NOS 12AX7 does on this tester most NOS tubes test between 80-90% this one tests at the high end of the scale in both sections.
Brian
One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM -
Sure sent you a message, if you want I will send you 2 more Mullard 12AU7's no cost they test low on my tester but they still sound very good so may last a while if you wish, a lot of low testing tubes will still play for years.Snow I will take #11 and #12 being the IEC Mullard 12AU7 off your hands, along with the RCA Clear Top 12AU7 Thanks
Regards Snow
Dan payment sent thanksHome Theater
Thank you I need your shipping address please, also do you want the two free Mullards?Dan payment sent thanks
Yes he missed them by minutes, I feel bad about not reserving them for him but I was not sure he was going to buy them, if someone states they will take a tube/s I will wait for payment for a few days but if they say they are interested and don't commit I cant hold them, its not fair to another member that wants them, many times I have held something for someone and they later decide they don't want themPost edited by snow onWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
PM replied.
https://youtu.be/ItUECpFi9_s
