Polk Badge Clips
Livinloud
I have no doubt I can get some constructive input. The 5a’s I recently picked up were missing the badges on the grills. I sources a pair that came with no clips. I am open to suggestions for securing them to the grills or sourcing new clips. Thanks in advance for the suggestions and advice!
Glue?Gustard X26 Pro DAC
Glue is easily an option but I would prefer something that would allow removing it if I need to redo the fabric at any point. I have read some good stuff about that Aleenes.
You're looking for push nut retainer clips. A Google search will turn up numerous options.Political Correctness'.........defined
President of Club Polk -
the part you want is often called a "spring nut" -- you'll have to determine the correct size based on the size of the post
example:
https://www.grainger.com/product/GRAINGER-APPROVED-Spring-Nut-Flat-Steel-Spring-1LAT2 -
I think he may be saying he bought flat ones like this, without posts on them.
Or maybe he just needs the clips? Those should be easy to find.
https://www.ebay.com/itm/166119046955?hash=item26ad777f2b:g:SBwAAOSwspBkbXks&amdata=enc:AQAIAAAA4IshZZSgt7dC25TmtlynstGM0PM/MDMDO9kKAr2rejv3ICbtY5aUdoKbkx3DVjLtYL/ezU4+1XNxMICiKTJ376tAPZTEGN+0xxJvJhDHvY+wR7u2I3a3Ya8fxXRhDLPr7tCcFcinpM+LmjPz8gcB7lmmmbFUgWn0nK8mdinQeJmcEZt9eKj4D+b2p1QAVtuC6Rs3JS+P+Dku7Xf4oXrL8BhFAb76+YPc5b1Ya5Z03Msk9Nid6j/sv+Tcbfw4k506E0kwFxljzPFzH1IEFR5MVO65TvMf3NG5lPiBguqzUe94|tkp:BFBM1qvJ6KVi -
I just took this photo of a few spares. You can just cut a small piece of sheet metal and drill a hole in it. You might have to cut a little. That's what they basically came with. Any Ace Hardware should have these in a drawer by the nuts and fasteners. F1Nut and Astrl55 have it correct a "push retainer" or "flat spring nut". -
Honestly I glue mine on. Keeps them from spinning and looking stupid crooked.Gustard X26 Pro DAC
Thx guys! I will run to the hardware store tomorrow armed with good info. The push retainer/flat spring nut is exactly what I am hunting.
aprazer402 wrote: »I think he may be saying he bought flat ones like this, without posts on them.
Yep, had to snag a pair of those, just for fun. Thanks for the link!
Brian -
I can double check in a bit but the hardware store had what they referred to as speed nuts or speed something… I will recheck the receipt in a bit. Anyway, they are an exact match to the clips @aprazer402 shows in the pics. The hole was a touch large but a pinch with some pliers closed the gap a bit and made for a tight fit.
That is another name they use and yes you can adjust just like you did.👍
