Help determining age and authenticity of Amperex ECC82 Bugle Boys
TIA
Picked up a small batch of 5 tubes this afternoon. The stenciling is a bit faded on some, but that's expected. Seller seems honest/legit, but he's not a professional tube dealer.
He does have a Western Electric tube tester and states all are strong (above the 2000 minimum). They came in plain white boxes with their values of 3100/3400, 3600/3600, 3700/4000, 3200/3600 and 3900/4000
The structure seems identical on the first 4 with a large Halo getter, the 5th getter diameter is quite a bit smaller and labeled a 12AX7A. All 5 have short grey plates
The first 2 are labeled ECC82/12AU7 whereas the 3rd and 4th are labeled 12AU7/ECC82
Near the base of the tube, the first 2 are marked 491 and one has a Gf3 above the 491
The 3rd and 4th have a marking like a triangle that's slanted right followed by 2F2
All state MADE IN HOLLAND and all have white stenciling
Also, the 5th tube (12AU7A) has a stencil # of 637
I won't get a chance to roll these til the weekend, but thoughts on VALUE and authenticity is appreciated . . .
(I'll load pics from another device in a minute)
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Best Answer
    heiney9 Posts: 25,497
    edited June 2023 Answer ✓
    Large halo Heerlen Holland tubes are almost always short gray plates (12Axx designation signal tube). They have the Delta Triangle. There was a transition between 1959 thru 1961. 1959 is almost always a large halo, 1960 can be both large and small halo and you might run into an odd 1961 dated large halo. I don't believe any short plate 12Axx tubes were made before 1959 so that's also transitional in that they were moving from long plates to short plates. Most likely for better stability and less susceptible to vibration, etc.
    What you are probably seeing in the "491" tubes is the "4" being a delta triangle with the "9" meaning 1959 manufacture date. Gf3 indicates its a short plate12AU7/ECC82 (3rd build run) I6x top line code is short plate 12AX7/ECC83.
    Above is a crude lesson. Check this out for more info.
    https://tubemaze.info/deciphering-european-tube-date-codes/#more-3636
    Other than the Gf or I6 coding, I'm not sure you can tell the difference between a 12AU and 12AX tube visually. The one with the 12AX7 writing, look for I6x in the top line of code.
    You can stencil any graphics on the bottle, but it's hard to "fake" the etched tube codes. Which is the only way to know what tube it is.
Answers
  • GlennDog
    GlennDog Posts: 3,158
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    nooshinjohn Posts: 26,000
    edited June 2023
    pitdogg2 Posts: 27,312
    2200 IIRC is new value.
    My meter doesn't go above 3000
  • GlennDog
    All values he has stated are above 3K. Anywho, he's a DIY guy as a bunch of his kit (that's in his equipment siggy) is home made
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    Come on @GlennDog haven't you been in this game awhile? 😉
    Tube lore is clear as spaghetti in heavy sauce !
    I suppose is doesn't matter as long as they perform as expected. I wanted them bc they can be rolled into my monos, DAC and the Backert pre that's in the closet waiting to be repurposed
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    Well Glenn there's good reference out there for the picking. The link above goes to Brents site and there's a link to download the information your requesting.
  • GlennDog
    everyones input is appreciated . . . thanks!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
