No subwoofer
Rebooted, everything i could find on YouTube. Green Light is on but no volume.
    tonyb Posts: 33,072
    Need a bit more info pal. Like, how is it hooked up and to what. Are the settings in the receiver correct ? Are you playing a dvd, bluray, and how is that hooked up and to what input on the receiver.
    Just for starters....
    msg Posts: 10,452
    Excellent work, confirmation noted.
    As far as I'm concerned, rebooting everything on YouTube is the only way to ensure a subwoofer stays quiet. You just can't trust that light, as you've noted.
    Viking64 Posts: 7,549
    Maybe this should be in the "Wanted To Buy" section. Still, if I wanted to buy a subwoofer, I would check eBay or Amazon before I tried YouTube.
    I have to admit, I don't understand the "green light" metaphor. Do you need someone's permission to buy a subwoofer? Because that changes things.
    Don't believe anything Scott (msg) says. He has been known to use Monster Cable and 8-track tapes after 1986.
