Psw350
TSHPro
TSHPro Posts: 1
I have a PSW350 that I am installing into my wall unit.
It is a very tight fit all the way around and I'm concerned the deepest bass tones might rattle the whole wall unit.
Besides placing the PSW350 somewhere else, is there something I can do in a tight space that could minimize potential problems and help sound quality?
Post edited by TSHPro on
  • CHRIS
    CHRIS Posts: 454
    edited May 2002
    Your going to get reverberation like crazy with it installed in a wall unit. It won't sound as good either, more muddy sounding. I would place it outside the wall unit if you can.
    Chris :)
  • mantis
    mantis Posts: 17,557
    edited May 2002
    Sub's are meant to be free standing.
    Whenever you put a box inside a box,your just looking for trouble.I would free stand it.
    Dan
