Refinishing an oak table
muncybob
muncybob Posts: 3,263
Now that I'm 99% done with the barn fence project, next on the list is the kitchen oak table that has a few scratches and several water stains. I would like to try a water based dye per Jesse's previous discussions but not sure I can match the legs or the chairs if I do that(I only want to work on the table top). I know Minwax Golden Oak is a very close match. But my main question here is , how do I finish the top so water stains and the like do not become a problem again? I think Jesse and I previously had this discussion but I can;t find it :(
Yep, my name really is Bob.
    F1nut Posts: 51,965
    Since you are diy, polyurethane. However, no finish can prevent water damage if exposed long enough.
  • muncybob
    Are there any advantages to a water based poly besides easier cleanup?
    It got to the point that a glass of water left on the table long enough to eat dinner was making a cloudy circle...it would go away after a few hours though.
    pitdogg2 Posts: 27,260
    edited June 2023
    When my dad refinished an antique Oak dinner table he used regular old polyurethane. This was 30+ years ago. Water doesn't seem to bother it. I've accidentally left a glass out had it sweat on the table and then the water was still there the next morning no cloudiness or rings. No granted I haven't left exposed water on it for more than just overnight or for a few hours but I didn't get rings or cloudiness.
    I'm pretty sure it wasn't water-based polyurethane.
    F1nut Posts: 51,965
    I couldn't say as I avoid water based finishes.
    Your current finish is likely lacquer. I suspect it is starting to fail.
    Poly has better moisture resistance, but it's harder for it to release any moisture that does manage to get through.
  • Emlyn
    Emlyn Posts: 4,814
    edited June 2023
    https://www.youtube.com/watch?v=jl7ofFaXCB4
    After it's refinished. I had to learn the hard way via a few clips to my head from my grandmother and mother.
    Viking64 Posts: 7,618
    I read an article where 3 kids were seriously injured on a coaster. They should have watched that video before going to that amusement park!
