Basil Hayden's
Upstatemax wrote: »Woodford double oak should be pretty easily found.
I picked up a bottle of Pikesville Straight Rye the other day at the recommendation of my buddy. It’s good stuff!
The Pikesville is one of my favorites. If you like Rye give the WhistlePig Rye a try.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Recently grabbed a bottle of Basil Hayden Dark Rye. Very enjoyable pour. Smooth without much burn.Things work out best for those who make the best of the way things work out.-John Wooden
If you haven’t already, try Basil Hayden 10 year. They typically release it in the fall. I like the regular Basil Hayden, but it is one of the smoothest bourbons I’ve had, which sometimes (to me) makes it taste like it is lacking some character. It just doesn’t have that punch to it, or burst of flavors that a lot of bourbons have. Sometimes that’s A okay, just depends on my mood.
The ten year is like if you take the smoothness but also add more flavor and character to it. It’s great. -
Not one of my favs. The BH just lacks a lot.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Just called our liquor store and told them to hold a few bottles of New Riff for me, yum!Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Another tasty under rated and widely ridiculously cheap option (in Rye whiskey) is Old Overholt...
Better than ryes costing 3-10 times as much.
Tried an Old Overholt on clearance that was very good. Next one was not good.
Have you seen much variance in it?Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
We tend to use Old Overholt in cocktails, I think it has been really good in that application. Haven’t noticed variation, but probably wouldn’t when it is mixed.
For the price I like Evan Williams BiB mixed 1:1 or 1:2 with Very Old Barton. Gives the oak and depth of EW and also cuts the sweetness of the VOB. Under $80 for 4.5L! (when buying 1.5Ls here in GA)Expect that there will be bumps in the road. Choose to not let them rattle you.
Every time I see this thread title, I think it's about some boxy British speakers.I disabled signatures.
Evan Wlliams BIB is my usual drink, very underrated and well priced. Just finishing up a 2 week project replacing 100+ 10' fence boards and 4X4 posts at the barn, celebrating with some BIB tonight!Yep, my name really is Bob.
Agreed. The EW BiB is my go to for mixers, but it’s certainly good enough to be poured neat. It’s the best bang for the buck that I’ve found…and I’ve looked long and hard😁Things work out best for those who make the best of the way things work out.-John Wooden -
EW BiB bothered my stomach by itself, even on the rocks. Mixed with the VOB, no problem.
