Polk Audio Monitor 7's?
I believe these are Polk Monitor 7's but the seller doesn't have that info in the description.
1. Can anybody tell me what tweeters these are and how they compare to the Peerless?
2. Can I replace these with a Peerless tweeter?
Thanks in advance
    xschop Posts: 5,415
    edited June 2023
    Look like 5B's with adhock PR's.
    They'll require the RD0's or Wuhan silk dome swap.
  • bcwsrt
    bcwsrt Posts: 2,515
    Must've been kept in some super-humid conditions. I used my 10s as garage speakers for a number of years after I got my 15s, but the hardware never rusted like that. Hopefully, you can hear them before you buy.
    Brian
  • MDN
    MDN Posts: 16
    xschop, thanks for the info. What is a PR? I have a pair of 5's, and mine look different as the woofer and driver touch/slightly overlap. That's why I thought they might be 7's.
    pitdogg2 Posts: 27,335
    Those do not look like original passive radiators(PR). The peerless has a different tweeter cut out than the SL2000 that would inhibit the peerless use.
    The 5 used 8" pr, the 7 used a 10"pr.
    Some of the screws did rust like that even here in the midwest humidity.
    F1nut Posts: 52,009
    Hard pass!
  • Livinloud
    Livinloud Posts: 43
    Hard pass!
    Agree! Though I would take them if they were free.
    The tweeter upgrade (rdo194) adds $100 cost but I would be more worried about the moisture that caused the rust. That wasn’t good for the rest of the speaker either.
