Smoke, smoke everywhere!
DaveHo
DaveHo Posts: 3,580
It's like a big campfire here in SE PA today. I hope the Canadian Wildfires get extinguish soon. I traveled to Haliburton scout reservation several years ago with our troop. Beautiful country. I pray things are brought under control soon!
  • Willow
    Willow Posts: 11,216
    It's pretty bad. I had to go to the office today. While there I went out to get some coffee beans and my clothes smell like I've been sitting next to a camp fire.
    Clipdat Posts: 13,078
    edited June 2023
    I know how bad this is from first hand experience with the California fires. It's absolutely **** miserable. Try to hang in there and be strong, it'll go away eventually.
  • TEAforONE
    TEAforONE Posts: 1,030
    Rochester,NY has been under the clouds of fire. As some of you might know,and many could care less,I’m a letter carrier. Thank the Lord, no issues health wise. I come home with campfire clothes is all. The station I work out of had smoke inside the building. I’m guessing time to change the filters! The sky had started to be seen again around 1:30 ish. It’s 8:00 pm,and it’s starting to haze over again. I think tomorrow things are supposed to change for the better.
  • Hermitism
    Hermitism Posts: 4,320
    TEAforONE wrote: »
    Frankenstein had a fear of fire. Just sayin'.
  • hochpt21
    hochpt21 Posts: 5,423
    We had a haze covering the sun in Wisconsin peaking on Sunday, but nothing like what you guys are dealing with. Hopefully it clears soon.
    xschop Posts: 5,063
    What started them all simultaneously?
    pitdogg2 Posts: 26,928
    xschop wrote: »
    Probably scouts earning their campfire badges...... B)
    J/K 😁😁
    audioluvr Posts: 5,872
    edited June 2023
    Get you one of these.
    https://www.amazon.com/Lasko-FF305-20-inch-Purifier-Purifying/dp/B089P1Z38J
    I use a 3M Filtrete 1900 taped to the back of a box fan when we have forest fire smoke issues. They're probably hard to find right now. They do a fantastic job of removing the smoke from your home.
    These'd probably work too. Not familiar with the brand.
    msg Posts: 10,450
    Which way does the fan blow, in or out?
    Trying to figure out how the filter works. Filter on outside of fan blowing into the house?
    edited June 2023
    I put the filter on the inlet side to keep the fan from getting grungy. Most furnace filters have a directional arrow printed on them for proper alignment.
    Scott, Ideally you want to use the fan with the windows closed. Smoke will get indoors any time you open the door. When the smoke was really bad here it would choke you stepping outside so you want to use the fan/filter as an air purifier.
    Portland 2020
  • TEAforONE
    Hermitism wrote: »
    TEAforONE wrote: »
    I wish I was that handsome!
  • muncybob
    muncybob Posts: 3,231
    Finally I can see some sky and the morning sun isn't a bright orange/red color. Still a haze though but better days are ahead!
    Yep, my name really is Bob.
  • Gardenstater
    Gardenstater Posts: 4,742
    Good site for checking current air quality. Near me this morning:
    https://fire.airnow.gov/#
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • motorstereo
    motorstereo Posts: 2,315
    My redneck airfilter is doing well on setting 2 this morning :)
  • Willow
    Smart, gives your coffee a smoky taste
    treitz3 Posts: 19,945
    You are doing it all wrong if this is to be considered a redneck setup. A true redneck setup would have fresh road kill in front of the filter to give it more flavor.
    Rookie.
  • motorstereo
    Ok then; will yesterday's backyard kill do or is it too late?
  • Gardenstater
    That site I gave above allows you to pull up a historical graph. Of course I was working outside like a du mbass yest. from 2pm to 6pm right at the peak:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    msg Posts: 10,450
    audioluvr wrote: »
    ohhh, okay, yeah, that makes sense.
    I sometimes stick a box fan in the window and wasn't connecting the dots there.
    lol - "ideally".
    we got a little haze yesterday morning, and slight scent of smoke in the air, but not as bad as some of those areas. man. we've had it worse when there've been wildfires just south of us in NC, but not of a long time.
    msg Posts: 10,450
    I like hedgehogs.
    What the heck are we looking at here?
    My guess would be a mole or vole...
  • motorstereo
    Yes it's a ground mole I caught in a trap. I got lucky.....the ground mole not so much.
    You would have to ask @lightman1 about that.
  • Gardenstater
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    edited June 2023
    F1nut Posts: 51,673
    xschop Posts: 5,063
  • aprazer402
    aprazer402 Posts: 3,352
    Stay safe!!!!
    It could be worse.
    F1nut Posts: 51,673
    aprazer402 wrote: »
    Stay safe!!!!
    It could be worse.
    Caused by climate change no doubt.
    edited June 2023
    xschop wrote: »
    That's not uncommon and not arson. A wave of thunderstorms came through just prior to that setting off small treetop fires which burned unnoticed until a high pressure system came through behind it (clear skies) creating high winds quickly drying things out and providing blast furnace amounts of oxygen.
