Smoke, smoke everywhere!
DaveHo
It's like a big campfire here in SE PA today. I hope the Canadian Wildfires get extinguish soon. I traveled to Haliburton scout reservation several years ago with our troop. Beautiful country. I pray things are brought under control soon!
It's pretty bad. I had to go to the office today. While there I went out to get some coffee beans and my clothes smell like I've been sitting next to a camp fire.
I know how bad this is from first hand experience with the California fires. It's absolutely **** miserable. Try to hang in there and be strong, it'll go away eventually.
Rochester,NY has been under the clouds of fire. As some of you might know,and many could care less,I’m a letter carrier. Thank the Lord, no issues health wise. I come home with campfire clothes is all. The station I work out of had smoke inside the building. I’m guessing time to change the filters! The sky had started to be seen again around 1:30 ish. It’s 8:00 pm,and it’s starting to haze over again. I think tomorrow things are supposed to change for the better.See my profile for list of gear.
Frankenstein had a fear of fire. Just sayin'.
We had a haze covering the sun in Wisconsin peaking on Sunday, but nothing like what you guys are dealing with. Hopefully it clears soon.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
What started them all simultaneously?Don't take experimental gene therapies from known eugenicists.
Probably scouts earning their campfire badges......
J/K 😁😁 -
Get you one of these.
https://www.amazon.com/Lasko-FF305-20-inch-Purifier-Purifying/dp/B089P1Z38J
I use a 3M Filtrete 1900 taped to the back of a box fan when we have forest fire smoke issues. They're probably hard to find right now. They do a fantastic job of removing the smoke from your home.
These'd probably work too. Not familiar with the brand.Gustard X26 Pro DAC
Which way does the fan blow, in or out?
Trying to figure out how the filter works. Filter on outside of fan blowing into the house?I disabled signatures. -
I put the filter on the inlet side to keep the fan from getting grungy. Most furnace filters have a directional arrow printed on them for proper alignment.
Scott, Ideally you want to use the fan with the windows closed. Smoke will get indoors any time you open the door. When the smoke was really bad here it would choke you stepping outside so you want to use the fan/filter as an air purifier.
Portland 2020
I wish I was that handsome!Rochester,NY has been under the clouds of fire. As some of you might know,and many could care less,I’m a letter carrier. Thank the Lord, no issues health wise. I come home with campfire clothes is all. The station I work out of had smoke inside the building. I’m guessing time to change the filters! The sky had started to be seen again around 1:30 ish. It’s 8:00 pm,and it’s starting to haze over again. I think tomorrow things are supposed to change for the better.
See my profile for list of gear. -
Finally I can see some sky and the morning sun isn't a bright orange/red color. Still a haze though but better days are ahead!Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
My redneck airfilter is doing well on setting 2 this morning
motorstereo wrote: »My redneck airfilter is doing well on setting 2 this morning
Smart, gives your coffee a smoky taste -
You are doing it all wrong if this is to be considered a redneck setup. A true redneck setup would have fresh road kill in front of the filter to give it more flavor.
Rookie.
Ok then; will yesterday's backyard kill do or is it too late?
That site I gave above allows you to pull up a historical graph. Of course I was working outside like a du mbass yest. from 2pm to 6pm right at the peak:
George / NJ
iFi nano iDSD DAC
iPurifier3
ohhh, okay, yeah, that makes sense.I put the filter on the inlet side to keep the fan from getting grungy. Most furnace filters have a directional arrow printed on them for proper alignment.
I sometimes stick a box fan in the window and wasn't connecting the dots there.
lol - "ideally".
we got a little haze yesterday morning, and slight scent of smoke in the air, but not as bad as some of those areas. man. we've had it worse when there've been wildfires just south of us in NC, but not of a long time.
I like hedgehogs.motorstereo wrote: »Ok then; will yesterday's backyard kill do or is it too late?
What the heck are we looking at here?
My guess would be a mole or vole...
Yes it's a ground mole I caught in a trap. I got lucky.....the ground mole not so much.
You would have to ask @lightman1 about that.
George / NJ
iFi nano iDSD DAC
iPurifier3
..Political Correctness'.........defined
President of Club Polk -
Stay safe!!!!
It could be worse.
aprazer402 wrote: »Stay safe!!!!
It could be worse.
Caused by climate change no doubt.Political Correctness'.........defined
That's not uncommon and not arson. A wave of thunderstorms came through just prior to that setting off small treetop fires which burned unnoticed until a high pressure system came through behind it (clear skies) creating high winds quickly drying things out and providing blast furnace amounts of oxygen.Gustard X26 Pro DAC
