Tilt base or no
I've read that enhanced speaker performance is gained by tilting the base up by about 6 degrees. Is this recommended for the SDA 1A's?
Answers
    treitz3 Posts: 20,039
    It depends on the speaker and the listening location height (height of the listener's ears). Some speakers can benefit from tilting them forward and some, even backwards.
    Easy enought to try it yourself with a couple of CD jewel cases or some books. It's a quick test to see if it would work in your particular situation.
    F1nut Posts: 51,872
    Dede wrote: »
    HELL NO!!!
    xschop Posts: 5,249
    If they still have the SL1000's or 2000's, tilt them as far back until you cannot hear them any more.
    pitdogg2 Posts: 27,152
    SDA's should not be toed in or tilted back.
    VR3 Posts: 29,487
    I will say there is really no harm or cost to try tilting it back.... Not like they will explode
    In theory
  • Emlyn
    Emlyn Posts: 4,777
    Could also just sit on a couple cushions and lean forward.
