Salamander Archetype 5.0 Stereo Rack Questions
vulcan
Anyone used or have experience with the Salamander Archetype 5.0 Stereo Rack?
I am looking to try something different and this system seems highly rated.
I need something very stable that can hold weight without wobble. I like the idea that the shelves are adjustable, as i recently bought a new preamp which is larger than the old one. how easy is it to adjust the shelves? thanks
Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
I’ve had mine about a year now and have been very happy with it. I’ll try to post a pic later, but I have a turntable, integrated, phono pre-, cd player, and power center to give you and idea of how much weight I have on it. It’s very easy to adjust. I just made a few changes to my system and adjusting the shelves was a breeze. You can do better, but I think you have to spend more to do so. Check Audio Advisor. I got mine as open box, but it was new for all practical purposes.Things work out best for those who make the best of the way things work out.-John Wooden
Things work out best for those who make the best of the way things work out.-John Wooden -
Thanks "PSOVLSK" for the info and pic. Great setup you got there and the rack looks very sturdy.Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
I have two of these, an A5 & A3. First thing I noticed was that they were heavier than they appear.
Note: If you buy the optional Mega Spikes, they are not true carpet spikes. They wont penetrate carpet, they are too thick. A member here had his megaspikes machined down to penetrate through carpet. There is a thread on here somewhere.
Here it is: https://forum.polkaudio.com/discussion/109330/salamander-archetype-rack-improvements -
Your cable management skills are to be commended! The only things visible are the speaker cables! 😳
Brian
