Salamander Archetype 5.0 Stereo Rack Questions
Anyone used or have experience with the Salamander Archetype 5.0 Stereo Rack?
I am looking to try something different and this system seems highly rated.
I need something very stable that can hold weight without wobble. I like the idea that the shelves are adjustable, as i recently bought a new preamp which is larger than the old one. how easy is it to adjust the shelves? thanks
Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
  • PSOVLSK
    PSOVLSK Posts: 5,396
    I’ve had mine about a year now and have been very happy with it. I’ll try to post a pic later, but I have a turntable, integrated, phono pre-, cd player, and power center to give you and idea of how much weight I have on it. It’s very easy to adjust. I just made a few changes to my system and adjusting the shelves was a breeze. You can do better, but I think you have to spend more to do so. Check Audio Advisor. I got mine as open box, but it was new for all practical purposes.
  • PSOVLSK
  • vulcan
    vulcan Posts: 99
    Thanks "PSOVLSK" for the info and pic. Great setup you got there and the rack looks very sturdy.
  • Hermitism
    Hermitism Posts: 4,329
    I have two of these, an A5 & A3. First thing I noticed was that they were heavier than they appear.
    Note: If you buy the optional Mega Spikes, they are not true carpet spikes. They wont penetrate carpet, they are too thick. A member here had his megaspikes machined down to penetrate through carpet. There is a thread on here somewhere.
    Here it is: https://forum.polkaudio.com/discussion/109330/salamander-archetype-rack-improvements
  • bcwsrt
    bcwsrt Posts: 2,448
    Your cable management skills are to be commended! The only things visible are the speaker cables! 😳
    Brian
