Component identification
nemohm
nemohm Posts: 19
Hi,
In a crossover upgrade activity there are 2 components in parallel to each other within the woofer low pass.
The brown is 3.3u capacitor.
What is the blue component ---1.5u Motorola MKT capacitor??
Answers
    pitdogg2 Posts: 27,255
    edited May 2023
    The Blue is yes a capacitor. The big M is also used to indicate +/- 20 percent tolerance. In your case the first M is most likely 1.5uf and the second M with the circle could indicate the +/- 20%. In the past I ran across another letter symbol that actually meant the value was MUCH more by like ten times. It was a 5 volt supercap that kept power for months and memory for presets. This is not what you have here.
  • nemohm
    nemohm Posts: 19
    Thank you, very helpful!
  • nemohm
    nemohm Posts: 19
    I believe it is MKT /mylar capacitor?
    VR3 Posts: 29,540
    If they are in parallel, a single 4.7uf should do the trick
  • nemohm
    nemohm Posts: 19
    edited May 2023
    They are in parallel, just wondering what could be the design function of parallel capacitors with different values, different types (the brown one looks as radial MKP).
  • Gardenstater
    Gardenstater Posts: 4,802
    edited May 2023
    Uhh well I can't see the brown one too good to be honest ;)
    Probably the intent was to do a bypass cap setup, where they do most of the desired capacitance with a less expensive cap and add a smaller value more expensive better sounding type in parallel to that. Supposed to take on a bit of the sonic character of the more expensive one.
    MKP (metallized polypropylene) would (probably) be better than MKT (metallized polyester or mylar).
    Post edited by Gardenstater on
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • nemohm
    nemohm Posts: 19
    I'm sceptical about bypass setup. Neither capacitor has a typical bypass value.
    VR3 Posts: 29,540
    Cost saving measure
    20 cent over 10000 speakers
  • Gardenstater
    nemohm wrote: »
    Right but if the brown cap is the better sounding more expensive one, then this is better than a typical bypass setup.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
