harman kardon
hexumjunkie
AVR 635 anyone think this is worth the grand i can get it for......
Post edited by hexumjunkie on
If you want it and and can afford it,get it.It's a good reciever.If the price is bothering you check out the 630 at closeout prices.Think it's just about the same,and if the 635 has newer software you can have the 630 updated.Harmon Audio is auctioning units every day on Ebay and have an internet store selling their refurbs with the same warranty as the new ones.I recently got a 430 and really like it.
As aubrey has stated .....
Go to HARMANAUDIO.COM . They too are on ebay HERE
HarmanAudio seems to have a very good reputation and could save you some serious $$$ .SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more -
I think you can get much better for $1k.
I had some HK stuff once.... ONCE.
Actually I still have my AVR-510. It's sitting on my floor right now, about to go back to Circuit City for service... for the third time. -
just picked up my old 430 from the repair shop today... yup, thank god I've got it sold. BTW, the 635 isn't shipped yet. There's a guy on ebay that's selling it for like $850 shipped but he doesn't have 'em. Hope you don't mind waiting. Or you could just get the Denon 3805 and have 3 times the sound quality.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
For a thousand bucks, I'd get an entry level receiver with pre-outs and a used 5-channel amp. That setup will probably sound better than any $1,000 receiver.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
It seems that some of you have had problems with the HK equipment.Care to elaborate????
The HK avr 635 can be had for $769.99 at J&R, and onecall, it can also be had for 799.99 at Vanns.com all of these are authorized retailers. The receiver has received positve reviews on other forums, but it has some of the same problems that plague Harman's previous receivers such as the sound defaulting to Dolby Digtal when ever that signal is present, but Harman has announced a software fix for this being in the works.
how does the new software work i mean how would u load it to the h/k
The firmware should be downloadable from the web and you would need a serial port on your pc to hook the receiver up, and apply the firmware.
but you'll void the warranty unless you have an authorized repair shop upgrade it for you.Never kick a fresh **** on a hot day.
No you won't void your warranty the download will be offered from Harmans own web site with instructions on how to install it on to the AVR. You can have a authorized service center do the install if you like but it does not void your warranty if you do it yourself. They already had a firmware update for the avr 630 and 430 to fix the audio dropouts, and add Prologic IIx
the paperwork I had on my 430 said it was only valid if upgraded via an authorized service center...Never kick a fresh **** on a hot day.
You can call Harman and ask them to be sure but it is covered.
Audio dropout?Do you mean the time the audio lags when making a change of settings or inputs,etc.?I have noticed the AVR switching to Dolby Digital without any prompting.
Which avr are you refering to.
The HK AVR430 is what I have now.Hope to get better service out of it than some of you guys have.Haven't had it long enough to complain or brag on it other than to say that I like the sound.Very clean power that exceeds my family's needs for movies and music.
bought the 635 this weekend....was suprised how heavy the thing was.....but it sounds very good....what volume level do people usually listen to tv at.....im not used to the negative numbers why does is rate like that?
The negative numbers indicate how much headroom is left.Proud SOPA Member since 2005!
just curious how you quantify sound quality??Originally posted by Toxis
I have Denon also and do prefer the sound to that of H/K, but doub't I can justify a baseless comment like it having 3 times the sound quality...
sorry, that comment just rubbed me the wrong way... -
Don't think that comment was meant to be taken literally. IMO, though, the HK is hard to beat SQ-wise. Not even the Denon 3805 can touch it.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
what do u mean by headroom? and how far up does it go?
bump
thanks!
