Replacement Tweeters
jgpiii
I need to replace tweeters in a pair of RTA 11t speakers due to toddler inflicted damage. Has anyone attempted to replace the stock SL2000 tweeters with anything other than the current replacement available from Polk? (For example, I've seen ADS tweeters available that look remarkably like the SL2000's and appear to have very similar dimensions.)
Post edited by jgpiii on
I like sticking with what Polk recomends, either using the same SL2000 or the current replacement.
Good luckDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
The only time I've replaced a Polk tweeter with anything else was when Peerless was still selling their "SL1000" tweeter.
I'd have to recommend that you go with the Polk replacement tweeter. I would also recommend that you replace both tweeters at the same time, otherwise there will be a noticible difference between the two channels.Ludicrous gibs!
