Helios CM DIY speakers complete
stangman67
stangman67 Posts: 2,329
edited May 2023 in DIY, Mods & Tweaks
Finally they are done (until I decide to pull them apart and rettack polishing them as I have lots of spider scratches I would rather not be there but that’s a problem for another day)
They are decidedly DIY in the outcome but I am incredibly happy with the turnout for my first build, learnt a ton of lessons along the way for whenever I decide to try again.
These are in my living room powered by a NAD m10 V2 and it’s a perfect living room setup in my opinion!
    VR3 Posts: 29,427
    I have seen manufactures with far worse finishes, I mean that as a compliment. You did a great job and they look great, you have every reason to be proud!
    xschop Posts: 5,174
    Great endeavor and a great job. I like that finish too.
  • Emlyn
    Emlyn Posts: 4,708
    Look great! Would they sound any different in the room with the bass drivers firing outwards rather than inwards?
  • stangman67
    VR3 wrote: »
    Thank you Trey! I really appreciate the compliment
    xschop wrote: »
    Thank you! It was certainly an endeavor and I think it will be a lifelong hobby.
    Emlyn wrote: »
    I’m sure it would sound different, the speakers are designed for the passives to fire inwards so I haven’t tried the other way
    VR3 Posts: 29,427
    I've found side firing woofers and passive radiators work best firing inwards as it couples them together in a way. Makes for a smoother in room response, ymmv
  • bcwsrt
    bcwsrt Posts: 2,411
    We are always our own worst critics. They look great. I wasn’t sure about the grey color, but now I get it. Perfect in your room.
    Brian
  • rooftop59
    rooftop59 Posts: 8,121
    those look really, really good. Congrats!
    So, how do they sound? Do you feel like the M10 has enough grunt to drive them well?
    Game Room 5.1.4:
    Bedroom 2.1
  • stangman67
    edited May 2023
    rooftop59 wrote: »
    They sound awesome! Super easy listening and tons of low end for a “bookshelf” (I use that term very loosely here lol). I am actually floored on how good they sound. I could live with these easily in my big system upstairs.
    I think the M10 has enough balls for these, it’s no powerhouse but it works. The speakers aren’t the most efficient design out there, I think a high current solid state class non class D would be the bees knees but I’m not disappointed in how the M10 drives these. I usually only listen at 80-85sb and the M10 can easily handle dynamics at that volume.
    Post edited by stangman67 on
  • ken brydson
    ken brydson Posts: 9,002
    Nice work, definitely above my pay grade (skill set)....
    txcoastal1 Posts: 13,513
    edited May 2023
    Those speakers came out great and there is a reason I ask for you to try these 2 songs
    Even through a BT Youtube connection
    Demo Sampler For Usher Audio - High End Audio Music
    https://youtu.be/ub2zHRGA2dI
    12. 45:13 Georgia on my Mind-Marie Nakamoto
    13. 50:27 O Holy Night
    You should here exquisite bass tones through those speakers that will make them sound like a full range tower
    Report back ;)
    Ultimate rendition
    https://youtu.be/7oGF42nwJcs
  • bcwsrt
    bcwsrt Posts: 2,411
    edited May 2023
    Georgia on my Mind-Marie Nakamoto...shame on me not to mention her beautiful voice
    https://youtu.be/VtbDTRZwx3c
  • stangman67
    I’ll give those a listen tomorrow and then report back
    msg Posts: 10,452
    Wow! Those turned out great, Zach! I like the finish and rounded edges. Very clean. Great job, and, jeez dude, your patience lol
  • skrol
    skrol Posts: 3,450
    VR3 wrote: »
    I have wondered why Polk designed the LSi15 and LSi25 with outward firing woofers. I thought the low end sounded better when I swapped them but the imaging suffered with the tweeters on the outside edge.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Emlyn
    Emlyn Posts: 4,708
    skrol wrote: »
    VR3 wrote: »
    That’s what I was wondering about. My guess is when the LSi series was developed as home theater speakers the common home theater display was either a large TV sitting on a big stand or a rear projection set. The LSi speakers would have the woofers firing straight into those if they were swapped.
    heiney9 Posts: 25,432
    Very nice. Congrats on a project well done!
    Clipdat Posts: 13,095
    They look great, and I bet they sound even better. Great placement, too. Enjoy the fruits of your labor!
  • WagnerRC
    WagnerRC Posts: 2,204
    well done Zach. Beautiful work!
  • stangman67
    msg wrote: »
    Thanks Scott! Lots of patience required and I recently had run out by the end. I’ll find some more later on and finish polishing lol
    heiney9 wrote: »
    Thanks!
    Clipdat wrote: »
    Thanks Drew, I’m super lucky my wife allowed these in the living room. The M10 certainly helped with the WAF as there aren’t components everywhere
    WagnerRC wrote: »
    Thanks Bob!
    Yeah the M10 looks like it fits right in there on the edge of the mantle! Perfect one box solution for that space.
  • stangman67
    Doing a little modification on these cheap mono price stands. Did up some walnut boards to set the speakers on. Finished in poly today. Next are the bases. Think I’ll go an inch wider and longer and go 1.5 inch thickness
    How is the sound?
    Where's my playlist review ?!?!? :pB)
  • stangman67
    txcoastal1 wrote: »
    How is the sound?
    Fine fine fine, here’s your review.
    First of all, the two tracks you asked me to listen to are definitely not my cup of tea so I had a hard time getting into them.
    I won’t mention anything on O holy night because it was overshadowed by that rendition of Georgia on my mind. I had to listen via Youtube so probably not getting the best results but it sounded great anyhow.
    Couple observations on a Georgia on my mind. The center image is beautiful and very precise which is something I always look for. You are correct about the bass authority, the natural bass of the instruments came through beautifully although a sub would certainly help in the lower registers. I’m also partial to a beautiful female voice and Marie’s voice did not disappoint.
    I have some placement work to do in regards to imaging, I haven’t messed with it much but imaging is pretty good, mostly constrained within the speakers footprint at this point. The room is a bit lively and will be receiving no treatment as it is our main living space but I think all things considered these speakers are absolutely incredible sounding.
  • rooftop59
    stangman67 wrote: »
    txcoastal1 wrote: »
    How is the sound?
    You might not care, but have you run Dirac Live? I am in a similar situation (main living area, can't really move the speakers, and treatments would only happen in my chitty apartment after my spouse kicked my arse out), and Dirac Live makes a HUGE difference in my room fwiw...and the upgraded mic is also helpful.
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,452
    I thought this was a new post, liked it, and actually unliked by accident. Don't worry, I reliked it.
    Hey Zach - you do know that perfectionism is not a good thing, right? lol
    I used to think it was, but it's actually indicative of a personality disorder, I think.
    Prediction: this Fall, Zach decides to take up woodworking and first project practice is scuffing up this nice "gray piano" finish to take glue for veneer.
    Prediction2: Zach puts these up for sale in three weeks when there's an elite piece of gear/speaker he wanted to buy in the first place, and he's found a way to fake out his wife when they arrive.
    Not really on #2. These are solid man, and I hope that you are truly enjoying them, and feeling fulfilled to the nth degree, because that was a hell of a lot of work, and I simultaneously inspiredly-envy and admire your patience and dedication. Plus, side passives? Those gotta sound awesome. Like, sleeper awesome for the size of the cabs. I really like the design of these, and was feeling impatient all along for you to hurry up and finish them.
    Unrelated side note - did you see that they've got the horrible moon-surface parking lot between piers 7 & 8 painted for repairs? Drive the second vehicle.
  • stangman67
    Lol I don’t think any of that is going to happen! Most likely coa is a buy a table saw and completely rebuild the cabinets if I get bored. Until then they stay as is.
    I am definitely a perfectionist but I allowed myself to look the other way so I could get these done and listen to them.
    Haven’t seen the work on NOB, it’s about time they do something about the roads and parking lots though. I’m stationed on NSA Hampton Roads now so I don’t have to deal with NOB often anymore
    msg Posts: 10,452
    lol - that's a great idea! you could tell your wife you're getting a table saw to rebuild "cabinets" and she'll think you mean kitchen cabinets! genius!
    Btw - to clarify on the perfectionism thing, that was a takes one to know one sort of thing! lol
    Ohh yeah, okay. I had to look that up to see where NSA HR was. I almost ended up in a role over near there. Cool, yeah, anything off the base is a little more like civilization.
    Some friends and I almost got arrested by some Marines one Halloween night when someone reported us jumping on that train that runs along Terminal near that area. Like dummies one of our friends parked in some little mini-Exchange gas station parking lot or something? which I think is still technically government property? lol Yeah, that was fun.
    And one of our buddies is a total redneck, and so his halloween costume that night was some weak cowboy getup - you know the kind I mean - the ones where the hat's too small? But not only did he look like a "happy" cowboy, but he was also carrying a mini Bowie knife, the length of which was still illegal.
    Sooo many things coulda gone wrong with that situation. I forget what happened in the end. I think the Marines may have been called to a more serious incident, but they ended up letting us go after giving our friend a sobriety test.
    But get this - this was back in my Air Force days, and i was home visiting and hanging out with my friends who were going to ODU at the time. The happy redneck buddy says to us all afterward - "Scott, I think you shoulda told them you're in the Air Force, and they probably would just've let us all go right away!" Maaaan, so clueless - those Marines woulda jacked! me up, made me responsible for the whole lot of us, prob locked me up, called my command and First Sergeant down in NC, and I've likely been spending the next two months as the First Sergeant's whipping boy, and that's if they didn't just kick me out! This was back in the 90s when they were downsizing.
    The train wasn't even going that fast.
    In case this is still an open case and an investigator has search locks out, I just made this whole story up, and I've never been out of my home area of Nova Scotia, up in Canada.
  • stangman67
    rooftop59 wrote: »
    stangman67 wrote: »
    txcoastal1 wrote: »
    How is the sound?
    I haven’t yet but it is something I’d like to try at some point. The Dirac option is really nice on this NAD gear, haven’t researched mics but I imagine a UMIK type mic is appropriate?
  • stangman67
    msg wrote: »
    This is the most junior enlisted story I’ve ever heard Scott! Sounds like you would have been fun to hang out with!
