What Will I Notice After Replacing Bad Capacitor?
I rebuilt my Monitor 10 crossovers today and upgraded the binding posts. I have a very low budget meter to check the values of the resistors and caps, but it seems fairly accurate. All of the new parts checked fine to within 3% of the stated values. Most of the original parts checked OK (+/- 10%) but one of the 12uF capacitors was way out of spec, measuring 16.41uF. It's the 12uF cap that also has the 2.5ohm resistor connected to it. Obviously the speaker should sound better now but what should I have noticed since that capacitor value had drifted that high?
    pitdogg2 Posts: 27,921
    Nice job!
    F1nut Posts: 52,406
    You probably didn't notice anything. What you will notice is how they sound now.
    VR3 Posts: 29,763
    Ultimately would change the frequency the tweeter plays.
  • Gardenstater
    Gardenstater Posts: 4,991
    edited April 2023
    What's the schematic?
    Raising the capacitance of a capacitor in series with a tweeter should lower the frequencies that the tweeter can play, for a 1st order crossover at least. 2nd order is more complicated. Would probably have given you a bit of a hump in the upper midrange though.
    If you are saying the 12uf cap (measuring 16) was in parallel with the 2.5 Ohm resistor, then it is a contour network that was designed to correct a rising response with decreasing frequency. Why they don't just say falling response with increasing freq. seems weird but whatever.
    I'm thinking it would be tuned for a lower frequency at which it would start to correct the dropping response and would cause a brightness
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • odcics2
    odcics2 Posts: 396
    Some very interesting information here:
    https://www.audiosciencereview.com/forum/index.php?threads/capacitor-upgrade-in-crossover-is-it-audible.12287/
    Also info on resistors and even binding posts.
    VR3 Posts: 29,763
    I'm not even going to click your link. I can and have recorded the differences with my cell phone much less test equipment.
    Caps, resistors, inductors make a difference. Period. There's no argument to be had here.
    msg Posts: 10,650
    @joebass3 - neat tester; where'd you find that thing? Did you build it?
  • joebass3
    joebass3 Posts: 311
    msg wrote: »
    LCR-T4 Mega328 Digital Transistor Tester Resistance Capacitance Diode Triode Capacitance Resistance ESR Meter MOS PNP NPN LCR with Case https://a.co/d/2xagWHZ
  • Jazzhead
    Jazzhead Posts: 526
    I find many posts on Audio Science Review annoying because IMHO not everything can be measured. I find it arrogant that some people actually believe they can measure every sonic nuance. Of course this will be an eternal argument about/among audiophiles.
  • odcics2
    odcics2 Posts: 396
    edited April 2023
    VR3 wrote: »
    Agreed.
    But you should read the link to understand what the guy tested and the results...
    Of course replacing BAD parts make a difference!
  • odcics2
    odcics2 Posts: 396
    edited October 20
    odcics2 wrote: »
    You ever actually replace caps/resistors/binding posts on speakers you were familiar with?
    Yes.
  • Gardenstater
    Jazzhead wrote: »
    Yeah like imaging for example. Nobody dares to dispute, not even those "audiosciencereview/ audioholics, that differences exist in that area that make or break one's listening experience. Do they have a measurement for that, and I am not talking about polar or off axis frequency response curves? Those don't show how one set of speakers localizes instruments and voices differently from another on a soundstage.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    invalid Posts: 1,560
    odcics2 wrote: »
    VR3 wrote: »
    Agreed.
    Keep listening to audio science review and you will only have a mediocre system at best.
  • odcics2
    odcics2 Posts: 396
    invalid wrote: »
    odcics2 wrote: »
    VR3 wrote: »
    Agreed.
    I like my Monitor 7B speakers.
    I like the way Matthew Polk voiced them.
    I also like to read facts and opinions about audio.
  • odcics2
    odcics2 Posts: 396
    Jazzhead wrote: »
    What’s not up for dispute is that we all hear differently. Perhaps a persons hearing test results should be posted along with their recommendations for audio devices!! Lol !
    VR3 Posts: 29,763
    txcoastal1 Posts: 13,520
    When I had my dedicated listening room. I had a pair of chairs similar to the one in the pic below. I could raise it up and down and recline. It took me a month running around Houston/Dallas to pick out of over 200 chairs I liked sitting in.
    Anyway, once the speakers are set, I could shift/adjust my chair an 1" and get better/lessor quality in sound.
    We have 2 ears and most testing is done with 1 mic. That mic does not tell you where that better position is located. Our ears on on the sides of our heads, and everyone's ears are shaped differently.
    There is no way that a measurement from a mic into software is the end all evaluation. There is no way that mic has any emotion to music.
    Mic and software are a base line and nothing else, IMHO
    F1nut Posts: 52,406
    odcics2 wrote: »
    invalid wrote: »
    odcics2 wrote: »
    VR3 wrote: »
    Agreed.
    You mean like the fact Amir tests only one of a pair of speakers to reach his conclusions? Or maybe the fact that actual listening does not occur?
    F1nut Posts: 52,406
    edited April 2023
    odcics2 wrote: »
    VR3 wrote: »
    Agreed.
    Parts don't have to be bad. Replacing the basic low budget parts found in the vast majority of speakers with high quality parts makes a difference.
  • odcics2
    odcics2 Posts: 396
    You said it!
    The fact that moving your chair an inch makes a difference in your sound quality means that another huge variable besides your ears is the listening room.
    They are all different.
  • odcics2
    odcics2 Posts: 396
    odcics2 wrote: »
    invalid wrote: »
    odcics2 wrote: »
    VR3 wrote: »
    Agreed.
    I use my ears. I learned a long time ago about basing my likes on reviews, graphs, charts and talking head opinions on the internet.
    I stand by my statement: I like my 7B speakers!
  • odcics2
    odcics2 Posts: 396
    odcics2 wrote: »
    VR3 wrote: »
    Agreed.
    But, is the “difference” good or not?
    I changed caps in a KLH 23 that made a difference for the worse. Putting the old caps in restored the sound in a positive way.
    F1nut Posts: 52,406
    Brand and model of caps?
    Theoretical:
    Speaker 1 Has a ring radiator tweeter, XX Mid, and XX woofer
    Speaker 2 Has a soft dome tweeter, XX Mid, and XX woofer
    When tested and measured that measure exactly the same....do they sound the same?
  • odcics2
    odcics2 Posts: 396
    Vishay Sprague.
    Been years, I don’t remember the exact model.
    F1nut Posts: 52,406
    edited April 2023
    odcics2 wrote: »
    Vishay Sprague.
    I'm not surprised you didn't like the results as they are not known to be high quality crossover caps.
  • odcics2
    odcics2 Posts: 396
    odcics2 wrote: »
    Vishay Sprague.
    Lol, yup. It was a lesson learned.
  • odcics2
    odcics2 Posts: 396
    txcoastal1 wrote: »
    Theoretical:
    Yes, if listened to in an anechoic chamber, so any room interaction is negated.
    In my entire life, I have yet to see two listening rooms the same. The same speakers will sound different in different rooms.
    For you, a theoretical:
    You have Five Grand of hard earned money to buy brand NEW speakers on the internet!
    They are so new that are no reviews by people yet to taint your opinions, just some measurements.
    Speakers A have excellent measured test results! +/- 1.5 db from 30hz to 20Khz
    Speakers B have a large mid bass hump, a large midrange suckout and very tipped up highs and various cabinet resonances. +/- 6 db from 30hz to 20Khz.
    Which ones would you buy for $5,000.?
  • invalid
    odcics2 wrote: »
    txcoastal1 wrote: »
    Theoretical:
    Really, you can hear the difference in the same room with the same equipment. An anechoic chamber isn't somewhere you want to listen to speakers in. You need to experience more and read about measurements less.
    F1nut Posts: 52,406
    100% correct. Being in one is an unnatural experience, creepy really.
