Theta Intrepid humming
I’m hoping someone may know some things to try before I store it away.
It’s a 5 channel amp I purchased a few years ago. It’s been fine this whole time but I moved it to the bedroom and I guess it didn’t like it.
Currently 4 out of 5 channels are buzzing/humming. My last attempt it made a huge sound and hurt my ear.
I’ve tried switching rca cables, unplugging all other devices. It does this without anything plugged in but the speakers. I tried multiple outlets and the one it was working previously.
Just wanted to run it by you guys.
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • invalid
    invalid Posts: 1,525
    Sounds like a bad filter capacitor, if it's doing that even in the previous outlet you were using.
    nooshinjohn Posts: 25,998
    The age of the amp alone indicates it's time for some maintenance
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    Thanks for the help on this. I’m going to try replacing the fuse. I pulled it out and it just all white so couldn’t see if it was busted or not.
    I emailed support and they said it needs to be serviced. Doesn’t hurt to try the fuse.
    Setup:
    treitz3 Posts: 20,116
    If the fuse is blown, there is a reason that it blew. Best to have it serviced first and have them replace the fuse. You don't want to compound the issue and create yet another possible issue.
  • invalid
    Do not power up the amplifier until it's been serviced!
  • KrazyMofo24
    Thanks never had anything serviced do you know about what’s typical on the cost?
    Setup:
    Theta was not cheap when new, so I expect costs to be somewhat higher than a bread and butter amp, but should still be cheaper than buying a new cheap amp, and you will have something that should run another 20 years.
