6500 anomaly
xschop
Got a set of these 6500s on the bench....
Never seen this before...
They both ohm out at 6.5 ohms...
1) No doping compound on cone so butyl surround is separating
2) Terminals affixed to outside of basket tab and no writing on label..
3) Magnets same O.D. but the oddball one is 0.110" thinner
4) Spider is shorter than normal on oddball one...
I don't see "polk" embossed in the surround of the bottom one in the first pic. Counterfeit?
Brian -
Good catch. I just measured it's dimensions and it matches factory however.
The biggest/strangest problem is that magnet is not shifted. So if Polk sent this out, then surely it's TS parameters are way out of spec in regards to BL.Don't take experimental gene therapies from known eugenicists. -
Pretty weird stuff there! What hangover day was that drive made on.....St. Patrick's Day?
In addition to the surround not having the "Polk" raised letters, the notch cutouts for screw locations still do look factory made but they are not rectangular, they are circular. Probably a different source mfg. for that surround.
If you take them apart can't wait to find out how the 2 magnets compare in breakaway strength with your pail of water technique!
PS: It looks like the pole piece back plate may have come from a different supplier as well because the circumference looks like it doesn't have the rounding that the more normal driver has. Pretty much a straight die punch operation without any rounding forging.
PPS: What are this driver's pronouns lol?Post edited by Gardenstater onGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I wonder if the height of the pole piece is also 0.110" less than typical. Maybe Polk was trying to reduce some of the excess cavity volume underneath the voice coil to change resonance/distortion characteristics? Also, maybe this driver's voice coil will have edge wound voice coil or maybe even double windings.
I think you HAVE to dissect this one for science
PS: If you remove the label is there an IEC mfg. code?George / NJ
iFi nano iDSD DAC
iPurifier3
RE: 6500 anomaly
The surround had been poorly and obviously replaced when I got that driver. Was wondering if it had been completely reworked by someone who did not know what they were doing. I understand if it is not salvageable. Thanks for doing whatever you can for it."Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson -
Even the gasket material is wrong. That is not a Polk driver.Political Correctness'.........defined
President of Club Polk -
Th gasket was missing when I got it. That was just the best material I could find for a gasket.
Have another 6500 on the way to replace the oddball, so xschop can have fun with the odball."Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson -
Will take a further inspection of it tomorrow.
What's strange is the label looks authentic as in original crusty faded paper label.
A legit 6500 with 0.54 thick magnet is a must. I could lightly coat with thin layer latex paint to solve that issue and try glue down surround better.Don't take experimental gene therapies from known eugenicists. -
That label was found under the stuffing in the cabinet the driver had been placed in. Assuming the driver was a 6500 I glued the label on it myself. Probably wont come off easily."Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson -
That's as weird as an inverted anticline! Welcome to Club Polk!Gustard X26 Pro DAC
Mystery solved definitely not OE
Did it have an EIA (I said IEC by mistake previously) manufacturers code? Was there a 557 which is Matrecs Industries?
Like in this thread:
https://forum.polkaudio.com/discussion/comment/2698515#Comment_2698515George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »Did it have an EIA (I said IEC by mistake previously) manufacturers code? Was there a 557 which is Matrecs Industries?
Here are a couple pics from when I first pulled the oddball driver.
https://forum.polkaudio.com/discussion/196707/is-this-driver-a-mw6503-if-not-what-is-it#latest"Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson -
I forgot that interesting thread. Hopefully not pre altzheimers lol. Anyways that part#, Mfg. # do not coincide with what we have seen so far on known confirmed MW6500s. The "8634" would be 34th week in 1986, which was probably a couple years after Polk was selling any speakers out the door with 6500s but I would have to make certain of that. Could still have been a warranty replacement driver. I purchased a Made In Mexico NOS open box MW6500 that has a Polk stamped date of 1999 on it so they were having drivers made still then. Some day I'll have to take the paper label off and see if there are any EIA Source codes on it.
You said in the other thread that you someone put a felt dust cap on top of the dust cap that was there? Not a good idea by the way, because it will throw the weight off and also the venting of the pole although the felt dust caps on my MW6500s are not very porous looking and probably do not pass much air at all. If the original cap underneath that one wasn't black felt, then that is more evidence that it is not a Polk MW6500, even one that was made with a different sized magnet.
George / NJ
iFi nano iDSD DAC
iPurifier3
1056 (?) is GEFCO Mfg. Co., Grayslake, IL.. All I can find out is a phone no. and they are involved in Household Audio and Video Equipment.
https://www.ecianow.org/assets/docs/EIAStandards/1.7.6_EIA Source Codes_1981.pdfGeorge / NJ
iFi nano iDSD DAC
iPurifier3
If it says Poke Audio, you know it's MIC.Don't take experimental gene therapies from known eugenicists.
X5095 Dual voice coil Gefco midwoofers FS on eBay. Not the same but shows the company was making similar drivers fo sho:
https://www.ebay.com/itm/134494355360
George / NJ
iFi nano iDSD DAC
iPurifier3
Intetesting. Looks like 2ea. of the same thin-size magnets on those.Don't take experimental gene therapies from known eugenicists.
Mystery solved... Pole piece is 0.110" shorter than all others Ive measured. So it sets in plane with the 0.25" thick base plate, as 0.25" protrudes past magnet.
Base plate ID doesn't have to be clearanced at 1.080", however the coil is cocked in the ID causing rub.
The different spider does not allow as much cone excursion, @30% less than a normal 6500...
I used the same black latex based paint to reseal surround and dope the cone...
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
Could it be one of the Mobile Monitor speakers? They were MM65xx. I have a few around that I can take some measurements.Stan
Main 2ch:
HT:
Other stuff:
You ain't cool unless someone's copying ya.Gustard X26 Pro DAC
What was their EIA Source Code? I couldn't find anything about "Mobile Monitor". Gefco was definitely 1056 for many years (1958 to 2001) according to this google doc study someone posted on the internet. I couldn't find Mobile Monitor in this:
https://docs.google.com/spreadsheets/d/1P1jeVIQ9UdwlhXTDLQEDxYuShjFQZO_4tUchw5_8N9o/edit#gid=174447209
George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »You said in the other thread that you someone put a felt dust cap on top of the dust cap that was there?
I should have been more clear in that post (got lazy?), I had assumed they had done this as I was convinced it was a 6500. Also it looked like it may have been the case.
I told Xschop to dissect the driver and discard it or experiment with it, whatever he wants, I won't use it either way as have another actual 6500 on the way.
Seeing that it is not a 6500, he will probably find my assumption that there a second dust cover to be invalid.
In the future I will be more diligent in not posting assumptions."Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson -
I knew that wasn't a Polk driver just by looking at it and said so earlier.Political Correctness'.........defined
Factory Polk looking felt dust cap (no-light transmission). I pulled it straight off the cone so I can test the rubber latex paint in that area of bare paper to see what it looks like when phase-plugging. The glue that attaches the dust covers to paper cones is very strong and some dust caps are applied after full cone doping or after, I have discovered...
The base-plate rivets are clocked different than factory drivers and the stamped steel basket is not quite as thick, along with it being a light/cheap coat of spray paint. All other authentic Polk drivers are powder-coated...
Not bad...
It's a Poke driver. Perfect for some destructive and repair testing.
Authentic 6500 with a burnt voice coil...
Perfect for a 6.5 ohm 25.9mm Wuhan coil...
Did you have trouble separating the spider and the surround from the basket? Drilled out the "rivets" from the front plate side?
Curious because I very well may try this on one of my silver basket OEM 6500s that has the stubborn to align voice coil (badly cocked). May have to separate voice coil from cone and reglue as well, in my case that is.George / NJ
iFi nano iDSD DAC
iPurifier3
It takes a .25" HSS bit to clear the rivet. You have to have the frame locked down to a press table and a controlled depth plunge/stop.
Once its off, you can chuck it up and clearance the ID very quickly with a boring bar. And add basket foam at leisure.😉
Will be testing a high strength glue out next...
This is true. But when someone tells me the sky isn't blue I need an explanation rather than a statement."Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson -
Ummm...look up...lolPolitical Correctness'.........defined
