Marantz SA8005 Problem
xsmi
in Electronics
So, I went to turn on my system to listen to some old Sanborn that I haven’t listened to in a while. I hit the power button and nothing. I checked all connections, still nothing. So I popped the top looking for a fuse or something that would be an easy fix. I don’t see anything. Does anyone have a repair manual, or keen eye for electronics failures?
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Does the red standby light on the front illuminate?
Fuse should be on the IEC power cord connection point.
Most have a fuse port on the front.
I don't see any inline fuse holder on the IEC plug.
It's circled in yellow.
Some on the front there's a tiny piece that comes out and has a tiny fuse. Use a good lighting source, it will say fuse or show a picture in most cases -
But it's just a basic two prong IEC. I don't see any fuse drawer:
Yeah I don’t see a fuse holder either. Bummer.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Oh well. I’ll have to look up the company who replaced my laser for me.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Maybe it's just a simple issue like a bad relay or something:
Never mind. It’s the cable. I never would have believed it. I’ve never had a power cable just go bad. And I have electronics from the 80’s that I still use.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
WHAAAAAT?!
Bad cable, BAD!
The blue device right next to the relay might be a fuse like device.Political Correctness'.........defined
