How did we miss this?
pitdogg2
in Electronics
Can see folks going to the bank to pull out a mortgage for their tubes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
16-20 of those would make a good high current amp!
Looks like a space shuttleCD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Well here's an 8-pack to get started.
So that announcement was from 2020? You know anything about these things, Ivan?
I disabled signatures. -
Not one thing!You know anything about these things?
Noodling around the intranet popped up and walla ain't that cool... -
Wish I had a use for them..
Space tech labs makes a few preamps that use that tube.
Could you imagine a big Carver Silver Seven built around 10 of these? If these can comfortably put out 85 watts each, that should be an unbelievable high current amp room warming space heater....
A pair of them would be pretty sexy -
That would be 1500 watts of tube power, but the specs say they can do 300/pair.Could you imagine a big Carver Silver Seven built around 10 of these? If these can comfortably put out 85 watts each, that should be an unbelievable high current amp room warming space heater....
Others have said they are powerful but not as musical as the 120s and 150s.
Might need to check out room 418 in a few weeks and see if they are showing any of them off there:
Brian -
Eros 500 Select Key Features
Sextet of KT150 output tubes create 250 watts of Class A musical power.
Class A power is fast for a more lively, immediate response to your music
So have they been tested with KT170's...
https://www.zestoaudio.com/eros-500-select-power-amp/2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
