How did we miss this?
pitdogg2
pitdogg2 Posts: 27,220
    VR3 Posts: 29,526
    Can see folks going to the bank to pull out a mortgage for their tubes
    VR3 wrote: »
    16-20 of those would make a good high current amp! :smiley:
  • jbreezy5
    jbreezy5 Posts: 1,141
    Looks like a space shuttle
    msg Posts: 10,458
    VR3 wrote: »
    Well here's an 8-pack to get started.
    So that announcement was from 2020? You know anything about these things, Ivan?
    edited March 2023
    You know anything about these things?
    Not one thing!
    Noodling around the intranet popped up and walla ain't that cool...
    Toolfan66 Posts: 18,156
    Wish I had a use for them..
  • invalid
    invalid Posts: 1,513
    Space tech labs makes a few preamps that use that tube.
    Could you imagine a big Carver Silver Seven built around 10 of these? If these can comfortably put out 85 watts each, that should be an unbelievable high current amp room warming space heater....
    A pair of them would be pretty sexy
    nooshinjohn Posts: 25,982
    That would be 1500 watts of tube power, but the specs say they can do 300/pair.
    Others have said they are powerful but not as musical as the 120s and 150s.
  • bcwsrt
    bcwsrt Posts: 2,486
    Might need to check out room 418 in a few weeks and see if they are showing any of them off there:
    Brian
    txcoastal1 Posts: 13,519
    Eros 500 Select Key Features
    Sextet of KT150 output tubes create 250 watts of Class A musical power.
    Class A power is fast for a more lively, immediate response to your music
    So have they been tested with KT170's...
    https://www.zestoaudio.com/eros-500-select-power-amp/
