Tube tester?
Is this a good tube tester?
Do you guys have recommendations?
I need a good tester for 6h30, 6550 for my audio research
Can a tube tester tell if they are about to blow for example?
https://www.ebay.com/itm/334751066249?chn=ps&mkevt=1&mkcid=28&srsltid=Ad5pg_F-AaTn8tTZiQR-BZjXPxcoSMhwL76pGlQtcCMjeS8eNIAIfUIHqqo
    F1nut Posts: 51,770
    The Hickok 539 or 750/752 series are some of the best. A tube can go bad at any moment, just the way it is.
  • Joey_V
    Joey_V Posts: 8,600
    Are tube testers rather simple to use?
    F1nut Posts: 51,770
    edited March 2023
    Joey_V wrote: »
    Like most stuff, easy for some and not for others. You shouldn't have a problem.
    Do none of your audio buds have one?
    pitdogg2 Posts: 27,047
    Reach out to Paul Hart and ask him, tell him what tubes you want to test.
    I had him work on my Hickok 600a, the guy knows he's stuff. He also sells testers that he has went through and brought up to snuff and fixed all that lost spec's.
    I can give you an email and phone number to reach out.
    Many old testers no matter how well they've been taken care of 50 to 70 years later they need work it's just the way it is.
  • skrol
    skrol Posts: 3,450
    I can't talk my dad out of his Hickok 600a. He still uses it occasionally to service his test equipment and ham radio.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • sucks2beme
    sucks2beme Posts: 5,683
    Regardless of how well it's made, time isn't
    Kind. A refresh and calibration are in order
    to be accurate. But if you just use it once in
    A while to see relative tube health, it would
    Be just fine. I have a Hickok stashed away.
    Those are well regarded as also well
    documented. Repair and calibration onto
    are all over the web.
    Clipdat Posts: 13,095
    edited March 2023
    Rare long plate getter
    I might hear microphonics
    Last Hickok calibration?
  • stereo55
    stereo55 Posts: 418
    Id recommend a B&K Precision 667 (solid state unit) . Nicely compact/small (compared to many) , super easy to use and accurate to the best of my testing and comparison to others such as the Hickok , etc over the last 10/20 yrs . ~ I do have other more pro/complete testers , but the 667 is my favorite for traveling to clients or sales where tubes need to checked . ~ I have two , one for travel and the second for home use when I dont want to breakout the big guns . ~ Both units still going strong and one has not needed calibration , the second needed mild calibration when first purchased , but nothing since . ~ Very nice units for the casual tester (or semi serious) , imo .
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
