Looking to buy some 6.5 mid woofer gaskets
odcics2
I need a few sets to replace mortite on some vintage Monitor 7 speakers.
Yes, I could make some from gasket material, or use dense foam. Those are options if I can’t find the real deals!!
I’d like to keep my 7s “original Polk”. Message me. Thanks
Many have used Armacell tape. Cut to width overlap at the end and cut on the diagonal, pick off extra so the diagonal cut meets at each end. It works very well and compresses very easily.
https://www.homedepot.com/p/Armacell-2-in-x-30-ft-R-1-Foam-Insulation-Tape-TAP18230/100539553 -
That’s a good plan B, if I can’t find original gaskets. 👍
Armacell is superior to the original...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
