Looking to buy some 6.5 mid woofer gaskets
I need a few sets to replace mortite on some vintage Monitor 7 speakers.
Yes, I could make some from gasket material, or use dense foam. Those are options if I can’t find the real deals!!
I’d like to keep my 7s “original Polk”. Message me. Thanks
    pitdogg2 Posts: 27,196
    edited March 2023
    Many have used Armacell tape. Cut to width overlap at the end and cut on the diagonal, pick off extra so the diagonal cut meets at each end. It works very well and compresses very easily.
    https://www.homedepot.com/p/Armacell-2-in-x-30-ft-R-1-Foam-Insulation-Tape-TAP18230/100539553
  • odcics2
    odcics2 Posts: 382
    That’s a good plan B, if I can’t find original gaskets. 👍
    nooshinjohn Posts: 25,972
    odcics2 wrote: »
    Armacell is superior to the original...
