WTB Musical Fidelity A3.2cr Remote Control
mabrow
Looking for the A3.2cr remote. It would need to be mailed to TX zip code 75028.
Thanks!
Thanks!
You can use a Harmony and download the codes. It will work a LOT better than the original.Political Correctness'.........defined
President of Club Polk -
Thanks F1nut. I do have a Harmony I can try. Where would I find the codes you mentioned?
On the Harmony site.Political Correctness'.........defined
Ok, thanks.
No need for any codes. Just enter the model number along with other devices and it will just control it. You might have to manually adjust certain buttons, but it should work…it does with my A308.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Thanks to all for the input.
Hey Paul, which Harmony do you like?
I have a harmony ultimate with the smart hub and ir extenders in every system. Bought them all used and love them!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
