WTB Musical Fidelity A3.2cr Remote Control
Looking for the A3.2cr remote. It would need to be mailed to TX zip code 75028.
Thanks!
    F1nut Posts: 52,018
    You can use a Harmony and download the codes. It will work a LOT better than the original.
  • mabrow
    mabrow Posts: 19
    Thanks F1nut. I do have a Harmony I can try. Where would I find the codes you mentioned?
    F1nut Posts: 52,018
    mabrow wrote: »
    On the Harmony site.
    treitz3 Posts: 20,132
  • rooftop59
    rooftop59 Posts: 8,120
    No need for any codes. Just enter the model number along with other devices and it will just control it. You might have to manually adjust certain buttons, but it should work…it does with my A308.
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,477
    Hey Paul, which Harmony do you like?
  • mabrow
    mabrow Posts: 19
    Thanks to all for the input.
  • rooftop59
    msg wrote: »
    I have a harmony ultimate with the smart hub and ir extenders in every system. Bought them all used and love them!
    Game Room 5.1.4:
    Bedroom 2.1
