Building an Ampex MR-70 playback preamp
  • SeleniumFalcon
    The company is called: JLCPB
  • SeleniumFalcon
    Some additional nuvistors arrive, some 6CW4:
  • SeleniumFalcon
    I prefer to use circuit board turrets for my connections, to my mind they allow for easy attachment and undoing of wires and I just plain like them. The smallest I could find of a good quality have a 1.6mm insertion base. Wanting to get a close tolerance fit I ordered, from McMaster-Carr, two drill bit sizes. The one on the left is 1.61mm and the one on the right is 1.65mm to see which one is better.
  • SeleniumFalcon
    I ended up using the 1.61mm drill bit with the slightly less deep version of the turret. The goal is to have a nice even rolling of the bottom end of the turret after striking.
  • SeleniumFalcon
  • Jetmaker737
    Jetmaker737 Posts: 1,144
    Is it just a mechanical connection to the traces (i.e., no solder)?
  • SeleniumFalcon
    After staking the turrets I do a continuity check between each terminal and the circuit board trace it's connected to. Then I solder the underside of the turret to the solder pad and repeat the continuity test. In fact I found a failure on one of the turret connections, so I'm scrapping that board and doing it over. That's why I had 10 boards made in case of a problem.
    There are two methods of staking the turrets that I've used. One is to place the anvil part of the tool in a vise and then using the staking tool (a rod with a shaped point) and a hammer tap the tool until the turret is firmly seated. The other approach (which I prefer) is a different anvil support that is a threaded bolt and a collar to hold the anvil. The threaded bolt is placed in a drill press table and then the striking tool is installed in the chuck of the drill press. Then with everything aligned the drill press handle presses down on the turret and makes a perfect punch. Unfortunately a longtime ago I left the anvil I was using in the collar instead of taking it out. Now the anvil is stuck in the collar and I can't change it to the correct anvil for this sized turret. So, I've ordered another tool from Mouser and have learned a lesson.
    With circuit boards this long holding the board while aligning the striker tool correctly over the turret and then hitting with just the right amount of force with a hammer is too unwieldy, I'll get the correct tool and do them properly this time.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,359
    edited February 2023
    Here's a photo of the last 6CW4 nuvistors I need:
    Post edited by SeleniumFalcon on
  • SeleniumFalcon
    A bundle of resistors needed for the main playback circuit boards:
  • SeleniumFalcon
    The Keystone terminal staking kit 1721:
    pitdogg2 Posts: 27,780
    Found your wing nut, 😂😂
  • SeleniumFalcon
  • newbie308
    Do you set the down stop so you rivet the same amount each time, or do you "get the feel" for when to stop?
  • SeleniumFalcon
    Now that you mention it, I should have used the down stop. No, I can feel a bit of resistance then a compression squeeze and it's set. I use a magnifying visor so I can get a close look at what is happening and check for the tightness of the fit and then a continuity check after each board.
  • SeleniumFalcon
  • SeleniumFalcon
    I've installed almost all of the resistors on both of the larger boards:
  • SeleniumFalcon
    The larger value WIMA and EPCOS/TDK capacitors:
  • SeleniumFalcon
    edited March 2023
    One of the goals in this project was to not use any electrolytic capacitors anywhere, including the power supply. I was able to find a 1,000uF and 2,000uF polypropylene capacitors. The Quaker Oats box is the large (42oz) size:
    xschop Posts: 5,747
  • SeleniumFalcon
    edited March 2023
    With the exception of a 0.5uF capacitor (I ordered the wrong part) the two larger circuits are complete. Now I have to finish the smaller, output stage, boards.
  • SeleniumFalcon
    xschop Posts: 5,747
    I actually looked in the pantry at a 42oz oat can and did a double-take. B)
  • SeleniumFalcon
    xschop Posts: 5,747
    I take it there's no Clarity Cap option.
  • SeleniumFalcon
  • SeleniumFalcon
    I've finished the second pair of circuit boards that contain the output circuitry. This circuit connects with an output transformer to create the balanced outputs.
  • SeleniumFalcon
    edited March 2023
  • SeleniumFalcon
    Now I'm working on the power supply, gathering all the parts. I ran into one difficulty, I ordered a 15mH choke from Digikey made by Signal Transformer, normally an excellent source of parts. When I got it the coil bobbin had been painted black but there were chips on several parts. I tested the value and it measured 11mH @ 1kHz instead of 15mH. So, I've begun a claim with Digikey.
  • SeleniumFalcon
  • ken brydson
    ken brydson Posts: 9,087
    Ah, Legos. Now I finally understand what you're working on... B)
