Rescued SDA SRS 2s
Brotherwolven
I recently picked up a pair of SDA SRS 2s from the curb on trash day not knowing anything about them other than the brand. I tested them this evening with my Technics SA-210. The right one sounded fine, but the left was all lows and no high end. I do not have the interconnect cable and wondered if that was the issue or if it’s something else. Any advice would be welcome.
Blade/blade or Pin/blade set?
Remove and test tweeters for continuity with a multimeter, report back -
Pin / blade. Will do with the tweeters.
For a curb haul, if you want to put in some effort and cash they could be awesome.
That's an amazing find.
The guys here can definitely help advise you.The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage -
Curb Find of the Year award goes to....
Hopefully you can get them up and running with little fuss.Don't take experimental gene therapies from known eugenicists. -
Tweeters have continuity.
Thanks all. I will probably keep them if I can get them working.
Time to start testing the board for continuity, maybe the poly switch has a broken a leg and that could be the problem.
