strange sounds from sob woofer and surround speakers
goodarzus
I have a magnifi maxsr
there are so mane strange sounds and crackles from my surround speakers and sub woofer
I tried to reset it many times but The problem has not been solved yet
my firmware version is 136
what should I do??
what should I do??
Let me ask a friend at Polk for suggestions.
Here is the response I received:
The Soundbar communicates with the subwoofer via RF. Other nearby wireless devices, including wireless routers, can cause communication issues which can result in popping or crackling sounds. Temporarily place the wireless surround speakers (or subwoofer) near the soundbar for initial re-pairing. Once paired, you can move the speakers (or subwoofer) to their desired location. Relocating other nearby wireless devices may be necessary. If you need more help, please contact Polk Support by visiting https://support.polkaudio.com/. -
thank you
I'll try it
SeleniumFalcon,
You’re a top notch Club Polk member…
You should be in employ @ Polk 👍 -
skipshot12 wrote: »SeleniumFalcon,
umm...
In all seriousness, @SeleniumFalcon is a great resource for all things Polk-y (and not so Polk-y, too)!
May I pile on with another shout-out to him for all he does (and his great photos, too)!
