What answer do you get?
Evidently there are two equally valid answers for this equation, each depends upon when you first learned math. Have fun!
  • stangman67
    stangman67 Posts: 2,329
    It’s 1. I don’t see how it could be anything else personally?
  • Jstas
    Jstas Posts: 14,978
    It's 1.
    There's no other answer.
    Order of operations.
    Parenthesis, multiplication and then division.
    One plus two is three.
    Three times two is six.
    Any number divided by itself is one.
    Six divide by six is one.
    Expert Moron Extraordinaire
  • stangman67
    Had to break out ole PEMDAS!
  • aprazer402
    aprazer402 Posts: 3,372
    Please excuse my dear aunt Sally. 1
  • Emlyn
    Emlyn Posts: 4,657
    Microsoft Excel won't accept the formula without a multiplication symbol between the first 2 and the parentheses.
    The answer is 9.
  • stangman67
    So apparently the correct answer is actually 9. Multiplication and division are equal in the order of operations (not how we were all taught). So you’d divide first as you go left to right when doing operations that are equivalent
  • stangman67
    I hate math
    mhardy6647 Posts: 34,950
    edited February 2023
    me, too.
    actually, I don't hate it, but I am terrible at math... and really pathetically terrible at arithmetic, especially when fractions are involved.
    I picked a kind of funny line of work. :#
    Our son is a mathematician and our daughter's an economist. They are amused when they watch me try to figure out, say, how much larger (in percentage) is 4 than 3.
    (I actually knew the order of operations thing -- but that doesn't mean I'd do it right)
  • Jstas
    Jstas Posts: 14,978
    Look, you can use the fuzzy math all you want but in every logical circuit design, the multiplication operator associated with the parenthesis gets operated on first because of it's association with the parenthesis. The division comes second because the parenthesis gives the multiplication a priority bump. It's known as "multiplication denoted by juxtaposition" and it sets a higher priority than a standalone multiplcation operator.
    Every computer out there including the one you are reading this on operates under that assumption for the order of operations.
    The answer to the equation is 1. Not 9.
  • stangman67
    Same thought process I had. I guess that’s why this question exists, just to piss people off lol. All the articles out there are saying the only right answer is 9. I never even considered 9 over 1
  • Emlyn
    Emlyn Posts: 4,657
    This will get 1:
    =6/(2*(2+1))
    :D
    treitz3 Posts: 19,964
    Question - Is the answer dependent on Common Core math or what?
  • vmaxer
    vmaxer Posts: 5,120
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Emlyn
    Emlyn Posts: 4,657
    No, the method has been used for more than a hundred years, but I do suspect common core math was just designed so parents could no longer help their kids with their math homework. :)
    The Google calculator also says the answer is 9.
    nooshinjohn Posts: 25,900
  • pearsall001
    pearsall001 Posts: 5,251
    My method is very easy & straightforward. Whenever I disassemble anything & after I reassemble there's always one screw left over! I get 1 too & I'm sticking too it!
    Danged fractions...
    xschop Posts: 5,110
    I guess it's just that fuzzy math. Nowadays the answer can identify with whatever number he, she, it, them, they prefer.
  • stangman67
    The answer actually identified as a letter, and it’s F (for F***)
  • maxward
    maxward Posts: 1,682
    If you didn’t want to intentionally confuse people, you could have written the equation differently, which I will not attempt here.
    Viking64 Posts: 7,533
    What a bunch of math nahtzees!!!
  • I too want the answer to be 1, but 9 is what I get when I think it through.
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • tonyp063
    tonyp063 Posts: 1,131
    Ken, you are an evil, evil man.
    <clap, clap,clap.>
  • daddyjt
    daddyjt Posts: 3,052
    All kidding aside, this leads to some pretty ugly outcomes as the new generation of engineers integrate into systems that were designed before their parents birth….
    ― Aleksandr Solzhenitsyn
  • "Why I aught to smack you with my slide rule, you twerp!" he he
  • jbreezy5
    jbreezy5 Posts: 1,141
    The common denominator of common core math = stupidity.
    msg Posts: 10,452
    9 - those who go to a concert and are okay with wild departures from the studio recordings.
    1 - those who go to a concert, and...
    (might scrub to 8:30; I don't think Vanilla picks up time jumps in yt links)
    https://youtu.be/VApKbScpMuY?t=510
    msg Posts: 10,452
    Math is a global, if not universal, language. There are basic rules and standards for its use and interpretation that make it work the same for everyone.
    Now, if you'll excuse me, I'm gonna go divide some Schiit by zero and see what happens.
