What answer do you get?
SeleniumFalcon
Evidently there are two equally valid answers for this equation, each depends upon when you first learned math. Have fun!
It’s 1. I don’t see how it could be anything else personally?2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
It's 1.
There's no other answer.
Order of operations.
Parenthesis, multiplication and then division.
One plus two is three.
Three times two is six.
Any number divided by itself is one.
Six divide by six is one.
Expert Moron Extraordinaire
Had to break out ole PEMDAS!2 Channel in my home attic/bar/man cave
Please excuse my dear aunt Sally. 1
Microsoft Excel won't accept the formula without a multiplication symbol between the first 2 and the parentheses.
The answer is 9. -
So apparently the correct answer is actually 9. Multiplication and division are equal in the order of operations (not how we were all taught). So you’d divide first as you go left to right when doing operations that are equivalent2 Channel in my home attic/bar/man cave
I hate math2 Channel in my home attic/bar/man cave
me, too.
actually, I don't hate it, but I am terrible at math... and really pathetically terrible at arithmetic, especially when fractions are involved.
I picked a kind of funny line of work.
Our son is a mathematician and our daughter's an economist. They are amused when they watch me try to figure out, say, how much larger (in percentage) is 4 than 3.
(I actually knew the order of operations thing -- but that doesn't mean I'd do it right)
Look, you can use the fuzzy math all you want but in every logical circuit design, the multiplication operator associated with the parenthesis gets operated on first because of it's association with the parenthesis. The division comes second because the parenthesis gives the multiplication a priority bump. It's known as "multiplication denoted by juxtaposition" and it sets a higher priority than a standalone multiplcation operator.
Every computer out there including the one you are reading this on operates under that assumption for the order of operations.
The answer to the equation is 1. Not 9.Expert Moron Extraordinaire
Same thought process I had. I guess that’s why this question exists, just to piss people off lol. All the articles out there are saying the only right answer is 9. I never even considered 9 over 12 Channel in my home attic/bar/man cave
This will get 1:
=6/(2*(2+1))
Question - Is the answer dependent on Common Core math or what?
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
No, the method has been used for more than a hundred years, but I do suspect common core math was just designed so parents could no longer help their kids with their math homework.
The Google calculator also says the answer is 9. -
My method is very easy & straightforward. Whenever I disassemble anything & after I reassemble there's always one screw left over! I get 1 too & I'm sticking too it!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
Danged fractions...
I guess it's just that fuzzy math. Nowadays the answer can identify with whatever number he, she, it, them, they prefer.Don't take experimental gene therapies from known eugenicists.
The answer actually identified as a letter, and it’s F (for F***)2 Channel in my home attic/bar/man cave
If you didn’t want to intentionally confuse people, you could have written the equation differently, which I will not attempt here.
What a bunch of math nahtzees!!!
I too want the answer to be 1, but 9 is what I get when I think it through.SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
Ken, you are an evil, evil man.
<clap, clap,clap.> -
All kidding aside, this leads to some pretty ugly outcomes as the new generation of engineers integrate into systems that were designed before their parents birth….“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
"Why I aught to smack you with my slide rule, you twerp!" he he
The common denominator of common core math = stupidity.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
9 - those who go to a concert and are okay with wild departures from the studio recordings.
1 - those who go to a concert, and...
(might scrub to 8:30; I don't think Vanilla picks up time jumps in yt links)
https://youtu.be/VApKbScpMuY?t=510
I disabled signatures. -
It's 9
Math is a global, if not universal, language. There are basic rules and standards for its use and interpretation that make it work the same for everyone.
Now, if you'll excuse me, I'm gonna go divide some Schiit by zero and see what happens.I disabled signatures. -
I got 42.
https://www.youtube.com/watch?v=URcUvFIUIhQ&t=318s
