T15 resistance
Soooo…. I have a set of T15’s, bought them used from a lil old lady. They look great. Went to use them, and thought “meh, what the hell. Better check resistance before I hook ‘em up” well, I’m reading 4.1 ohms on each once. Specs say 6-8. Seems really fishy. So, I checked with my other fluke meter and same. Are these common to fry like this? I just rebuilt my crossovers in my T75’s because of this. Any clue if this is normal?
  • I don't know if you are comparing a DC resistance measurement with nominal impedance rating? If so they are definitely 2 different things entirely.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • machine
    machine Posts: 36
    edited February 2023
    Yeah… but dc resistance usually reads within 10% of AC impedance on an 8 ohm speaker from what I’ve seen. Is this not the case with these?
  • Sorry, I couldn't say without seeing the schematic. Capacitors don't pass DC.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,959
    What those specs really say is the speakers are compatible with 6-8 ohm power sources. Polk needs to do a better job listing specs.
    A typical 8 ohm speaker will measure between 5 and 7 ohms of resistance, so from that I think it's likely the T15 is a nominal 6 ohm speaker. Therefore, 4.1 ohms at the posts means there's nothing wrong with your speakers.
  • machine
    machine Posts: 36
    Well thats a relief. Something is up with my Marrantz SR6005 avr then. When i connect the surround speakers, the right one is cutting out then quits altogether.
    F1nut Posts: 51,959
    Well, there could be a cold solder joint somewhere inside the speaker.
  • machine
    machine Posts: 36
    Just switched speaker and the problem stays on the same channel. Going to pull apart the receiver later and check the output terminals. Oh, and this is the schematic for the T15’s. Simple first order crossover. I might upgrade the caps while my receiver is down.
