Polk model 7a crossovers
Trying to repair or replace the crossover on a model 7a speaker, are they same as model 7, and can anyone recommend where to buy the capacitors especially the 4uf 50vac
Β«1
    F1nut Posts: 49,819
    Monitor 7, not model.
    The Monitor 7 is the 7A.
    Sonic Craft has everything you need.
  • Gardenstater
    brcarman wrote: Β»
    There are some minor differences but so far I have not heard of anything but 12 uF mylar capacitor in the high pass (tweeter) circuit and a 34 uF electrolytic capacitor in the low pass (midwoofer) circuit.
    Are you sure about that 4 uF or did you perhaps misread it?
    What is your serial # and/or manufacturing date (often put on the crossover and sometimes the midwoofers)?
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • brcarman
    Thankyou for answering, and yes it is 34 uf havnt removed the old so could only see the 4, in trying to find capacitors it's the vac can't find, I did find the 12 uf in a higher voltage dc, would prefer to fix myself if can find what I need, but there are used model 7s crossovers on ebay, the tag on back reads model 7a and the serial number is 11178, I so much! Appreciate any help thankyou, Bill r
  • Gardenstater
    Gardenstater Posts: 4,195
    edited February 2023
    Those are quite earlier than my Aug 1979 7B which were 19XXX (can't remember exact). Do you have 2 fuses on the terminal cup?
    The metallized polypropylene capacitors you are best going with for an upgrade are going to be quite a bit larger and 200V and above. You won't likely find below 200V rated ones. The resistors you are best off replacing with something like Mills/Vishay wirewound non inductive or the like and it is advisable to go with 10W or even 12W to handle the heat better and run cooler for less thermal noise. You probably have 4.5 Ohm and 2.7 Ohm 5W ceramic (sandcast) resistors but I have seen some early ones with 4.7 Ohm and there may be others. I even saw one with one 10W and one 5W
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • brcarman
    I have a 4.7 ohm, 10% and 2.7 ohm 10% resistors, my peerless tweeters works but didn't work in the box connected to crossover, the base sounded muffled and the 34uf cap looks like it's bulging, I don't know anything about upgrades, back to factory specs ok with me, but whatever I have to do to get them sounding good, and there are two fuses on the back, I believe they are worth fixing?
  • Gardenstater
    Absolutely worth fixing. There were some Monitor 7 (don't remember if 7A or B ) crossovers for sale on eBay. You could always snatch them up if they are still there. Upgraded caps and resistors sound amazing though, as well as internal wiring which you can always do all that later.
    Just checked and there are two pairs on eBay but both are single fuse 7Bs 40XXX and 22XXX, so if you went with those you would no longer be original.
    You could transfer your 4.7 Ohm resistors over. Problem is that I do not know for sure if inductors were the same in the earlier ones like your 7As. We don't have any early schematics. If you have the MW6500 drivers which I am fairly certain you must, I can't really forsee any problem with going with the 7B crossover.
    https://www.ebay.com/itm/325513956918?hash=item4bca24ce36:g:kE4AAOSw6-dj1AOE&amdata=enc:AQAHAAAAoNzyxJjra5/g2DM9Ns9fz66KwcizSM+cG/1gMBBIhbogIrM3y2VU+S1BAQX2ysQusqT1mrQbn5MMCIAi3ePC+MP7MeWdtj8gOs5wiqaOlNJJuiCggxVB0FICWpMe95B2746HptOfOBl9tSMeIESee4O95jcn0rGpkcjVi3euDZpwVGNgdkAO6URC/kGXl5tMGHAoI5FsgUWnrUnZviGgTy8=|tkp:Bk9SR5bL85PFYQ
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • brcarman
    The other numbers on resistors are 7806 trw pw5, and 7745 trw pw5 on the 4.7 ohm one, I'm not up on all the terms, but took hobby electronics in high school, and these look easy to repair soder to me,
  • Gardenstater
    Yes. It should be very easy for you then. The pw5 means 5Watts
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 49,819
    Don't buy used crossovers, fix yours.
    The first thing you need to do is clean the ends of the fuses as well as the fuse holder clips. They oxidize over time. The eraser on a pencil works well for that. You should also verify the fuses aren't blown. Do you have a VOM?
  • brcarman
    Ty for answering me I don't have a meter but looks like I should get one, I'll recheck the fuses and condition of holders
  • brcarman
    Thankyou both, I think I have enough to go on, and will leave ya all alone, for now lol my sincere appreciation, was about to pull my hair out after trying just find caps all day
  • Gardenstater
    No problem. I'm guessing you want to find out how they sound stock before upgrading. I can tell you the parts list to basically use the components I used (Sonicaps capacitors and Mills resistors) if you are interested. I purchased them all from Soniccraft.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • brcarman
    Would appreciate Any info, and sounds like that sonicraft is the go to place, I pick up a near mint pair of pioneer pm60s a bit back, and am anxious to see how these polks compare, one speaker sounded good far as could tell but the other one no tweeter sound and bass was awfull
  • brcarman
    Also would like to do my own repairing, because those pioneers are old too ,so thinking just a matter of time till they will need crossover work too
  • brcarman
    Looks like 1nut was right and I was rt too lol, from your info and the serial number mine must be 1978. They have the little factory holes in the tweeters, gonna take one nuts advice and recheck the fuses and connectors, and both your advice and hit up soniccraft tomorrow. Thanks a bunch guys!! I'm 59 and not to social media savvy, you have made my first experience excellent, Bill r
    F1nut Posts: 49,819
    Bill, it's F1nut.
  • bcwsrt
    bcwsrt Posts: 1,609
    Posts = ~48,000
    Respect = 0
    πŸ˜³πŸ™„πŸ˜‚
    And while we’re at it, it’s Sonic Craft. πŸ˜‰πŸ˜‹
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Sony CDP-508ESD CD player (as a transport) | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    xschop Posts: 4,719
    F1nut wrote: Β»
    Bill, it's F1nut.
    Yeah Bill, 1nut has a twin, 2nuts. F1nut has no relation.
  • Gardenstater
    bcwsrt wrote: Β»
    Posts = ~48,000
    Respect = 0
    πŸ˜³πŸ™„πŸ˜‚
    soniccraft.com (no space)
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Post edited by Gardenstater on
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 49,819
    bcwsrt wrote: Β»
    Posts = ~48,000
    Respect = 0
    πŸ˜³πŸ™„πŸ˜‚
    The business name is Sonic Craft as was correctly posted. The correct site address is https://www.soniccraft.com/
  • brcarman
    Sorry f1nut, no dishing intended
  • brcarman
    Hope these pics sent this time
  • brcarman
    Thankyou Gardens tater for the links, I think there called
  • brcarman
    I guess I had opened two two different discussion pages, I did post pics and answered questions on the other one lol sorry, beginner here, you guys are great πŸ‘ ty Bill
  • brcarman
    Help Gardenstater, I posted that I was going with the parts connection stuff, and when I went back to write down that info it was gone! Did that happen because I hit the question answered spot? Hate to ask but could you please repost the parts connection numbers, ty
  • brcarman
    Oops the info was still on the other post so no need to repost . I'll improve, I'm not to literate on these forums but learning
  • ken brydson
    ken brydson Posts: 8,651
    brcarman wrote: Β»
    I know it's a typo but...
  • brcarman
    Was I guess a funny typo,lol, but I'll tell you what, Gardenstater went beyond the call of duty to help me, I hope he received my final plan and thankyou to him. He even located All the prices and even part numbers and where to buy them, and I am truly grateful. Bill r
    xschop Posts: 4,719
    George's moniker is lengthy. Maybe he won't mind if we call him 1-tater?
