Help! Newb here - rebuilding my first crossovers from Monitor 75T's
2
    xschop Posts: 5,659
    edited January 2023
    I'd try a set of these if anything, since they're 4 ohm and easy to swap in....
    https://www.parts-express.com/Dayton-Audio-ND25FN-4-1-Silk-Dome-Neodymium-Tweeter-Element-4-Ohm-275-053?quantity=1
    txcoastal1 Posts: 13,519
    xschop Posts: 5,659
    I'm sure they'd sound much better than the soundbar Polk would suggest.
  • xschop wrote: »
    Thanks for the suggestion, but I didnt see it until I already ordered a pair of Eminence SD28's. If the Daytons are a higher quality speaker, I can always return them. Only ordered the SD28's because I read that it was "A common replacement for the Polk 75T tweeters with slight faceplate modification."
    Plus, I remember someone saying Dayton was
  • txcoastal1 wrote: »
    Uh oh, what did I do now?
  • Meme(ing) is a fine art here.
    That Dayton is 90dB sensitivity, 3.7+ Ohm min. impedance and the Eminence is 92.5dB, 3.5 Ohm min. impedance. You haven't been able to find any data for the OEM tweeter?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Specs:
    Impedance: 4 ohms
    Re: 3.0 ohms
    Voice Coil Diameter: 1" (25.4mm)
    This is about all i can find
    xschop Posts: 5,659
    Soundbar United won't have any details on anything they've designed via planned obsolescence.
    Good find on the Emminence driver. Another member here suggested a Dayton driver for RtiA and possibly TSi models if the tweeter takes a dump. Looks like a quick epoxy install too.
  • machine
    machine Posts: 36
    edited February 2023
    Just a little quick 3d printed bushing and the Eminence tweeter fits perfectly. Little superglue to leakproof and the tweeter snaps right in. I then go behind the tweeter and melt the bushing over the edge of the tweeter in a few spots to lock it in. dtu4xghnfpkc.jpeg
  • machine
    machine Posts: 36
    And here’s the larger installed upgraded parts on a small factory board. Had to do some vertical integration and design and print a bracket for the gigantic 9.1uf cap and neighboring resistor.
    xschop Posts: 5,659
    Looks good. Might want to move the resistor away from the larger Clarity cap.
  • machine
    machine Posts: 36
    I’m assuming that’s because of heat? How hot do they get? They are about 3/16” to 1/4” inch apart.
    xschop Posts: 5,659
    That's the consensus. I've pulled my x-overs from my 5Bs so many times that I can confirm they do get warm after long playback periods.
  • Mundorf resistors? What wattage did you go with? Not trying to be contradictory and maybe it is a photographic illusion but they appear to be closer than 3/16" gap between them and the ClarityCap. It would just be wise at this point to give a little more space for airflow. Keeping the temp. down reduces thermal noise.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • They are Dayton resistors. The other resistor is close to the inductor, about 3/8” above the board. Do the inductors get hot and/have issues? There’s just not a whole lot I can do with these small boards. Those eminence tweets do sound great though. I did try one with the Solen cap, and it did sound better than OEM, but it was pretty sharp. Glad I was shamed into buying the clarity’s. I usually use this system for mostly watching movies and music when playing the drums, so they aren’t pushed too hard. I have the AVR LPF cutoff bottom out at 60 Hz, and the powered sub goes up to 110, so there’s a slight overlap. I still can’t believe how good these sound. Also found out my AVR was getting hot and cutting off because of the bad crossovers, thought the reciever was dying.
  • And a big thanks to EVERYONE that chimed in and helped me learn more about these. I might design my own crossovers and build some cabinets as a winter hobby once I brush up on 2nd order systems and Bode plots. Makes sense now!
    xschop Posts: 5,659
    Will you rebuild/make new cabinets for those?
    Also, what is the major diameter of the tweeter faceplate?
  • xschop wrote: »
    xschop Posts: 5,659
    machine wrote: »
    xschop wrote: »
    Yep, I was thinking Polk had 2 versions of these plates, judging by pics. Here are my near-field modded TSi100s. I plan on making a set of billet plates that close the gap better between them and the MW trim rings...
    What does yours measure from c2c (green) on the screw mounts?
  • Using calipers and referring to the above colors, Blue= 4.405, Red=3.700, Green= 3.250
  • machine
    machine Posts: 36
    What drivers are those? The OEM ones? Just wondering because I have a set of the TSi200’s, and they look different. If the tweeters are going, the Eminence ones sound great and are an easy install if you have a 3d printer.I can send you the file I created if needed.
    xschop Posts: 5,659
    They are oem with the laminate removed and phase-plugged. From pics of your 75T's they are the same originally.
    Ill machine alloy faceplates for mine, but thank you for offer.
  • You can remove the plastic layer??!
    Huh.
    Nice 3D print fixes by the OP. Well done.
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • More pics for anyone that comes across this in the future tkujysaybaye.jpeg
  • That's a great idea. I wish' I'd thought of that when making my bracket recently.
  • cowbot
    cowbot Posts: 4
    Any update or progress on this? I faced with repairing a couple of 75T's with terrible sounding tweeters.
    Thanks!
    xschop Posts: 5,659
    edited April 2023
    I got around to fixing the deforming bezels.
    I used high density polyurethane and let dry.
    Almost doubled the weight and now the top edge sits flush with the cabinet...
  • cowbot
    cowbot Posts: 4
    So just to confirm, the resistor marked "5WR75J" is a 7.5 ohm, not a 0.75 ohm? I thought the R indicates the location of the decimal point (and 5W = 5 watt, J= 5% tolerance)
    F1nut Posts: 52,160
    That is a 0.75 ohm resistor.
    xschop Posts: 5,659
    machine wrote: »
    Any updates on your Xover burn in?
    Curious how the upper midrange melds with the new tweets.
