Diagnosing & Fixing Shifted Polk MW Drivers
The Polk logo embossed into the bottom of the surround on the MWs would then be upside down. How severe is your OCD?Brian
My ocd is waaaaay f’d up but, my memory is worse.
If I don’t remember it never happened. -
I rotated all of mine in all my old speakers..The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
Well I spoke too soon. One of my repair jobs missed the mark and I have some strangely intermittent coil rub. I can see the pole is just a tad off-center. Wish I had used the epoxy on the outside... Anybody have experience on loosening red loctite without a torch?
You'll have to heat it with a butane torch. Put the flame directly on the flat top of the pole piece in a circular motion while plying with a putty knife between magnet and base plate.Don't take experimental gene therapies from known eugenicists.
Thanks @plastic_avatar and @xschop After my research online I'm afraid you're right. I think my friend has one. Next time I'll use the two part epoxy (and just do the outside edges right?). -
That is a bummer! Do you think it re-shifted after you re-centered it, or do you think you might have missed it by a little when you re-centered it?
(...and yes I just do the outer edge as noted in the write-up, haven't had an issue with re-shifting *knock on wood*)
my 3.1TLs
I will fix your shifted magnets for free.
Strangely, it's intermittent. Right now it's working fine (sounds so good). I'm pretty sure the coil was moving freely when I glued it (I kept reveling in pushing it up and down with two fingers on either side of the dust cap every few hours when it was drying!)
A bit more data (maybe there's a clue?):
Yesterday I took the dustcap off and pushed the dust coil out to see if there's any damage or maybe something stuck, but the coil looks OK. And then it was fine- the rubbing stopped! But then it came back a couple of hours of use later. So I played with again (just kind of pushing in out by hand). And then the rubbing stopped again. (and so far hasn't come back...)
The only thing I can see is that it isn't perfectly symmetrical (pole is just a little closer on one side). I did rotate the whole speaker so the smaller gap is at the bottom. I'm sure gravity wouldn't effect any thing, but why not...
Anyway, right now it sounds great and my whole family took turns listening to Space Oddity last night. Super fun. We'll see what the future holds (possibly a butane torch, but I have an eBay alert for a MW6011 in the meantime!)... -
If it's a 6511, their suspensions are real saggy and can rub if they're not dead-center.Don't take experimental gene therapies from known eugenicists.
These wouldn't be MW6500 would they? Those have a smaller radial clearance from the OD of VC to ID of front plate. Another possibility could be a particle between the VC former ID and the pole piece OD. Sometimes you can push it down out of the way with a shim.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »These wouldn't be MW6500 would they? Those have a smaller radial clearance from the OD of VC to ID of front plate. Another possibility could be a particle between the VC former ID and the pole piece OD. Sometimes you can push it down out of the way with a shim.
I mistyped- Its the MW6511 (mistakenly typed MW6011) -
I had someone send me a pair of woofers that he said rubbed a little, but I couldn't for the life of me get them to rub, so we agreed that I would just send them back, he re-installed them, and no more rub.
Maybe that could have been a loose suspension issue as well? Point is - I've seen a case of intermittent rubbing in addition to yours.
@robosdad Did you happen to mark the orientation when you heard the rubbing, compared to its orientation now, no longer rubbing?
my 3.1TLs
@lawdogg orientation of the entire speaker? If so, I do not remember orientation when I reinstalled the speaker the first time. After I took them out and played with them, I coincidentally put them back in the same as all the others, with the little wire nodes (at the rim of the dust cap) at the 6 o'clock position. I say coincidentally because I put them back in such that the smallest gap between the VC and the pole was at the bottom, thinking that gravity might possibly work in favor pulling the coil down.
Ok, well, something to keep an eye on if it starts to rub again I suppose. But I hope it doesn't!
my 3.1TLs
One thing I forgot to add- when I first saw this thread, I didn't realize @lawdogg was offering to fix these things for free. Obviously, now, I see that his generous offer is embedded in his signature. On my computer, the long horizontal lines in the sig look like the long horizontal lines separating posts, so at the time I thought the sig was a post from a different user posting right after lawdogg's posts, and it was some kind of message board troublemaker that everyone was just ignoring, and that they were soliciting repair services with a "free" angle! Anyway, thought you all might get a kick out of that. Thanks again for the help- still loving the SDA-1c's (that one finicky woofer is still good to go!)
Catch someone a fish and you feed them once; teach someone to fish and you feed them for life!
my 3.1TLs
Got a pair of 7B speakers, one MW 6500 is seized. Measures 6.1 dc ohms, out of the cabinet.
Good MW measures 6.0 dc ohms still being wired in the cabinet. (Is that a valid number, being still wired?
Early in this thread, MW 6500 are stated to be 6.8 ohms.
Any insight appreciated. Thanks. -
They are supposed to be 6.50 Ohms across the driver terminals, out of circuit. I'd have to check mine to see what I get across the binding posts if that is what you are referring to.
https://forum.polkaudio.com/discussion/133992/thiele-small-parameters-for-mw6500-drivers#latest
PS: On a spare stock crossover I have I get around 0.7 and 0.8 Ohm (2 different meters) across the binding posts with no driver in the circuit and driver fastons held together. I do not trust these low resolution meter for this measurement however.George / NJ
iFi nano iDSD DAC
iPurifier3
I pulled the good speaker out of the cabinet and measured across the terminals, not at the speaker input.
Incidentally, the one good 7B is 100% airtight and the MW / PR combo sounds great. Goes deep on urban test music.
Testing done in a garage, not my small dedicated room. -
OK then I wasted my time I guess. That was not clear because for the one you said "still being wired in the cabinet".George / NJ
iFi nano iDSD DAC
iPurifier3
Sorry for not being clear and concise in how I measured the driver.
So, driver out of the cabinet, measuring across the terminals which were still connected to the wires.
No prob. But the answer to this is no and will give same reading across the driver terminals whether the fastons supply wires are connected or not. Should measure 6.5 Ohms. There are lots of cheap inexpensive meters that can be off however.
"Good MW measures 6.0 dc ohms still being wired in the cabinet. (Is that a valid number, being still wired?"George / NJ
iFi nano iDSD DAC
iPurifier3
I should get myself a better ohm meter!!!
Most of what I own is questionable for measuring these low resistances, but I get around 6.4 Ohms on my drivers that I have measured. The way to find out would be to get some 1% tolerance resistors in the 1 to 7 ohms range and see how your meter does.George / NJ
iFi nano iDSD DAC
iPurifier3
@odcics2 If you wanted to check the accuracy of your ohmmeter you could get something like this:
https://www.parts-express.com/Dayton-Audio-DPR10-6.5-6.5-Ohm-10-Watt-Precision-1-Audio-Grade-Resistor-006-6.5George / NJ
iFi nano iDSD DAC
iPurifier3
I think I saw your post over on AK about the dog knocking it over!
If the magnet flew off, how does the voice coil look? Visibly OK (e.g., nice and cylindrical, no discoloring)?
my 3.1TLs
