Best integrated amplifier for Polk Audio L800?
Jarod888
Jarod888 Posts: 61
edited January 2023 in Speakers
Hi Everyone,
My current integrated amplifier is Rotel RA-1592 MK2, works fine with L800, but I'd like to upgrade my amp because I love my L800 and want to pair them with the best amp I can afford.
So my two questions are:
1, what's the best Polk officially recommended integrated amplifier for Polk Audio L800?
2, what's the best integrated amplifier for Polk Audio L800 you would recommened?
Thank you very much!
    F1nut Posts: 51,855
    It's like deja vu all over again.
    pitdogg2 Posts: 27,121
    Drop dead sexy stuff that double D
    tonyb Posts: 33,072
    There is no such thing as "best", only what sounds good to your ears. If the Rotel is kicking it for you, then roll with it. Personally I find most Rotel gear a bit on the dry side and not as engaging as some others. That's just me though, everyone has different tastes.
  • Emlyn
    Emlyn Posts: 4,751
    What's the price range under consideration and what's not appealing about the Rotel's performance? I wouldn't recommend going to a different brand that doesn't have as much current available to the amp section as Rotel's 1592 model. That means spending roughtly double. There are a bunch of models at the next price range up of around $6K to $10K. Some won't be compatible with the L800s if they use a differential amp design.
    I'd consider preamp and amp separates rather than trying to get more out of an integrated amp.
  • marvda1
    marvda1 Posts: 4,952
    @Jarod888 why did you ask this in two different threads?
    Puritan PSM156
    F1nut Posts: 51,855
    He's banned, move on.
  • pearsall001
    pearsall001 Posts: 5,306
    I was just going to give him my recommendation...ah shucks🤗
    By the way it is Wilson Audio.....Facts man you need facts!
  • bcwsrt
    bcwsrt Posts: 2,428
    So is this like the 4th time you’ve been back here and just keep adding another “8” to your handle?
    Brian
  • PSOVLSK
    PSOVLSK Posts: 5,396
    Not if you buy them out of the back of a white van.
    msg Posts: 10,452
    bcwsrt wrote: »
    I thought those were special side-mounted infinitys
    audioluvr Posts: 5,956
    He started with Jarod1.
    nooshinjohn Posts: 25,935
    Isn’t Jerod doing time for kiddie ****?
    F1nut Posts: 51,855
    Firstly, the Musical Fidelity M8xi you recommended is a diffrential output amp
    No, it's a single ended design that offers balanced inputs/outputs.
