Digital Coax and USB cables
nooshinjohn
Let me begin by saying that I do believe cables make a difference, but I am skeptical about digital coax and USB cables offering much improvement. I run AQ WEL from my Arcam to the amps, AQ Meteor Duble Biwires to my L800's and Douglas Connections for the rest of the setup.
I am looking to use Coax out from my Oppo 203 to the Simaudio 380d, and need recommendations for the Coax and also for the USB connection from my PC to the DAC... I also need to understand if there really is that much improvement by laying out $$$ for these cables. Everything is sounding really good as it is.
Not only do they make a difference, the connectors and length play a role.
1.5m bnc digital cable for coax. Everything else is wrong!
One of the biggest improvements I experienced was from the digital coax- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The only coax I can use needs rca termination. What about USB?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I recommend changing the rca jacks in the equipment to BNC
I'm not as versed in usb- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm curious about the bnc connections as well. What happens when bnc to RCA adapters are used?I disabled signatures.
The problem with rca connections is they can't ever truly be 75 ohms guaranteed.
Bnc is 75 ohms guaranteed!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
*Within a tolerance of 10%. If in doubt, ohm it out.
Damn, I 'm a poet and didn't know it.
Little bit more to it than that, good article to show how
https://www.jackenhack.com/cable-impedance-how-to-measure/- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I just picked up an Audioquest Diamond USB to go from my computer to the Moon 380d DSD... in for a penny I guess.
@VR3 has it right, characteristic impedance is a difference type of measurement for a transmission line cable.
