Digital Coax and USB cables
Let me begin by saying that I do believe cables make a difference, but I am skeptical about digital coax and USB cables offering much improvement. I run AQ WEL from my Arcam to the amps, AQ Meteor Duble Biwires to my L800's and Douglas Connections for the rest of the setup.
I am looking to use Coax out from my Oppo 203 to the Simaudio 380d, and need recommendations for the Coax and also for the USB connection from my PC to the DAC... I also need to understand if there really is that much improvement by laying out $$$ for these cables. Everything is sounding really good as it is.
    VR3 Posts: 29,715
    Not only do they make a difference, the connectors and length play a role.
    1.5m bnc digital cable for coax. Everything else is wrong!
    One of the biggest improvements I experienced was from the digital coax
    nooshinjohn Posts: 26,124
    The only coax I can use needs rca termination. What about USB?
    VR3 Posts: 29,715
    I recommend changing the rca jacks in the equipment to BNC
    I'm not as versed in usb
    msg Posts: 10,626
    I'm curious about the bnc connections as well. What happens when bnc to RCA adapters are used?
    VR3 Posts: 29,715
    The problem with rca connections is they can't ever truly be 75 ohms guaranteed.
    Bnc is 75 ohms guaranteed!
    msg Posts: 10,626
    I remember you mentioning that now.
    treitz3 Posts: 20,324
    edited January 2023
    *Within a tolerance of 10%. If in doubt, ohm it out.
    Damn, I 'm a poet and didn't know it.
    VR3 Posts: 29,715
    Little bit more to it than that, good article to show how
    https://www.jackenhack.com/cable-impedance-how-to-measure/
    I just picked up an Audioquest Diamond USB to go from my computer to the Moon 380d DSD... in for a penny I guess.
  • invalid
    invalid Posts: 1,556
    @VR3 has it right, characteristic impedance is a difference type of measurement for a transmission line cable.
