Daisy-Chain 4 speakers @ 8 ohms each -- from a PSW 10
I have a Yamaha A100a amp, and 4 8 ohm passive speakers. Can I use my powered PSW10 as the amp from which I daisy chain 4 speakers?
    F1nut Posts: 51,758
    No
  • jwing
    jwing Posts: 6
    Please just answer the question as directly as possible.
    treitz3 Posts: 19,989
    No x2.
    VR3 Posts: 29,427
    Psw10 amplifier fails driving its own driver so I wouldn't count it in the ring to drive 4 more.
    txcoastal1 Posts: 13,512
    jwing wrote: »
    Question was answered directly as possible....NO!!
    Now a 1ohm load on a subpar amp
    mhardy6647 Posts: 35,005
    Well, I mean, one could connect the four loudspeakers in a series-parallel array and get a manageable impedance -- or connect all four in series and get plenty of impedance.
    ... but just because one could do something does not, a priori, mean that one should, of course.
    edited January 2023
    Yes you can series each pair then put each series in parallel
    F1nut Posts: 51,758
    Guys, he wants to use the sub amp to drive the speakers.
    Can I use my powered PSW10 as the amp...
    Yup.
