Custom amp faceplate
I dig it
Laser cut and etched
Black acrylic
    VR3 Posts: 29,521
    VR3 Posts: 29,521
    Blue light!
    nooshinjohn Posts: 25,973
    Emotiva edition… :p
    VR3 Posts: 29,521
    My printer may break
    F1nut Posts: 51,925
    Put a higher value resistor on that led, it's blinding.
    pitdogg2 Posts: 27,205
    edited January 2023
    It looks very nice.
    To be frank for whatever reason to my eyes blue LEDs just scald my retinas. Must just be the wavelength that the blue sits at, even Xmas lights outside at night from a great distance make me want to turn away.
  • bcwsrt
    bcwsrt Posts: 2,476
    Intense blues appear very blurry for me. It's the worst with blue neon. Used to bother me more in my youth for whatever reason. But, I still like the move to blue LEDs from red, especially with black.
    Nice work!
    Brian
    VR3 Posts: 29,521
    Thanks guys
    What value resistor do you recommend?
    I will include different resistors when I go to sell them... Clear, blue, red, white, green
    F1nut Posts: 51,925
    edited January 2023
    VR3 wrote: »
    Thanks guys
    Not sure what to recommend as it varies with the mcd rating (intensity) of the led. Do you know the mcd rating of that one?
    You can get low mcd leds with diffused lens, which really cut down the glare. You can also use fine grit sandpaper (400 grit) to create a diffused lens out of a clear lens. However, if the mcd rating is high no amount of diffusion will cut the glare.
    The viewing angle rating plays a role too. Narrow angles are more intense when viewed straight on, but much less so when viewed at a wider angle.
    VR3 Posts: 29,521
    Gotcha, it is recessed in the faceplate so I will try coating it with an opaque finish to dial it back
    F1nut Posts: 51,925
    IMO, you're better off installing a low mcd led to start with. Believe it or not a 5 or 10 mcd led is plenty. They have ultra bright ones rated at like 10,000 mcd, which will cause permanent retina damage, IMO.
