Life with the Legend L800
  • tjcinnamon
    tjcinnamon Posts: 100
    My L800 are in a 19x15 room with the speakers on the long wall. They are 42” off the side walls, and 7 feet or so apart. 10 inches from the wall and not toed in. I sit eleven feet back, with 4 foot behind me. I get strong imaging, SDA and precision placement of instruments within the soundstage....
    My situation isn’t nearly as nice.
    8 feet off side walls
    7 to 8 feet apart
    9 seated distance
    With about 1.5 feet behind me
    nooshinjohn Posts: 26,184
    How big is the room?
  • tjcinnamon
    12’ deep
    7’ high
    24’ wide
    Move them to one of the short walls
  • tjcinnamon
    Forgive my ignorance, does shortwall mean it’s close to a side wall?
    It means to get the proper spacing, try rearranging the room to get the speakers placed on o e of the 12 foot walls...
  • tjcinnamon
    Dang! I wish. I have an inwall atmos set up with TV. It’s a 7.6.4 system with a 77” TV in between. For my next house though…
    I’ll see if I can add some movable partitions to make some fake walls. I think I could do testing with cardboard or maybe a thumbtack board to experiment creating a wall
  • mpitogo
    mpitogo Posts: 524
    edited March 2022
    I’ve had my L800 in 3 orientations 2 in one house and 1 in my new. I found that closer together in an equilateral triangle 7’ apart 7’ from each speaker face to your ear gave me the best SDA effect. This was with my second orientation. I find that farther away or speakers further apart weakens the IAC cancellation signal.
    1st try back in Nov 2019
    Best one moved from long wall to short wall in 25x15 room
    New house setup, still figuring it out moving 1in at a time but I think I got it. Current setup is 4” closer together now tthan when this picture was taken.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    I am experiencing Elvis with The Royal Philharmonic Orchestra right now. Simply spectacular... The scale and majesty of this recording brings Elvis to life and the speakers melt into the ether. I am finding that the L800, in my space, paint a soundscape that transforms my room into a virtual experience that has to be heard to be believed.
    Clipdat Posts: 13,107
    Was that from vinyl or digital?
    Clipdat wrote: »
    Streaming from Qobuz.
    heiney9 Posts: 25,724
    How do like Qobuz? This is the one I am considering getting a subscription to. Excellent sound quality, good selection, ease of use, reliable, etc, etc. ? Do you find yourself streaming quite a bit?
  • TennMan
    TennMan Posts: 1,266
    tjcinnamon wrote: »
    Now I’m pivoting to try and get the SDA effect stronger
    Even though it sounds counterintuitive, sometimes moving the speakers slightly closer together gives better (wider) SDA. Also, moving your listening position up into the triangle a little might help SDA.
    heiney9 wrote: »
    I like it a lot so far. They have an impressive library. I have been using it almost exclusively since I discovered it a few months ago. It is easy, and I have never had an issue, though on a live recording, it is distracting to hear the track break. I have yet to figure out how to stop that, but otherwise, I have been impressed.
  • Emlyn
    Emlyn Posts: 4,920
    The good thing about the L800 is they work well when pulled out forward into a room like regular speakers operate. Makes it easier to pinpoint the sweet spot in the listening room.
    VR3 Posts: 29,763
    Yeah when we were at Troy's they sounded much better 3 to 5 ft out into the room
  • Emlyn
    Emlyn Posts: 4,920
    I've also found they can tolerate being closer together than regular stereo speakers. I didn't trust that setup recommendation at first but found it to be true.
    John what are you using for a streamer?
    Clipdat wrote: »
    A desktop PC over HDMI.
    Well if it sounds this good now, wait until you get a Innuos, Lumin, Auralic, Aurender, etc. !
    Clipdat wrote: »
    My Arcam is also a streamer, but I have yet to mess with those functions.
    Well you know, wouldn't want to rush into things.
  • erniejade
    erniejade Posts: 6,327
    heiney9 wrote: »
    I have both Qobuz and Tidal. Even having 2 pay streaming services, I have been saving money not buying CD's. Without MQA, I pick Qobuz any day of the week. A lot is available in high res without having to have a decoder and, in my opinion, even 16 bit cd quality stuff sounds a bit cleaner, more natural highs over Tidal. Tidal has more bass though. The only hard part when comparing the 2 in non MQA is you really have no idea what master version they are using since sometimes there are several different versions of the same album.
    I am running an Innuos Zen MK III for my streamer.
    I continue my love for the L800... I am listening to Pink Floyd's "Wish You Were Here" on Qobuz and the bass these speakers can dig to is amazing, tuneful and articulate. The layers of individual instruments, vocals and synthesizers combine into a sonic landscape that is absolutely a delight to hear. It is like I never heard this recording before.
    I find that happening frequently as I listen, that I am hearing things as if I have been missing details forever that are now suddenly and viscerally there. What a joy it is to rediscover my music and hear things I never knew were there.
  • invalid
    invalid Posts: 1,560
    I like the sound of qobuz better than tidal, but they are missing some music that tidal has.
    treitz3 Posts: 20,367
    Both Tidal and Qobuz are missing certain tracks/albums/versions/live recordings.
    Glad to hear you are enjoying both the speakers and the Auralic, John.
    The Auralic (it’s prior owner anyway) has been a pain in my AZZ for two months now, going on three… I just picked up a Simaudio Moon 380d DSD. It sounds better and the display won’t ghost out like the Auralic did.
    Oh, that's right. I forgot about your issues with the Auralic. Congrat's on the Simaudio!
    I have tomorrow off work and I'm spending the day with the L600's. Also Monday off and I'll be spending the day with the L600's. Looking forward to getting some really good listening in.
    I'll be rocking a lot of Jeff Beck too......damn that was a gut punch.
    Glad you're enjoying the L800's.
  • kimmy7988
    kimmy7988 Posts: 1
    edited January 2023
    Question. I had the L800 for a month and noticed that majority of vocals are coming a little towards the left side, utilizing the SDA. Is this because how the recording was done? I’ve noticed the following main vocals’ stage placement from my music collection: 10% from center, 60% left side, 30% right side. Most of the older records’ main vocals’ stage is a little on the left side…. Newer records have more dispersed stage placements, not towards more on the left side.
