Super Bowl of surfing LIVE you tube
The Eddie is back and is live on you tube today.. It hasnt been run for years,2016 as the standards are quite strict and calls for solid surf in the 20+ range and the swell today is pushing a solid 30, which makes for 60 foot faces which makes for some epic surfing. The best of the best will be there
