Monitor 7 RDO 194 vs Monitor 7B Peerless
Toolfan66
If you were going to choose?
Why?
Can a person still get peerless tweeters?
Why?
They (Peerless) seem to be getting harder to get and in rougher shape than years past.
The original silk domes are comprised of a protein that deteriorates over long periods.Don't take experimental gene therapies from known eugenicists.
If the Peerless tweeters were original to the Monitor 7s and still worked fine I'd think twice about replacing them. Any other situation and I'd use the RD0 tweeters and wouldn't think twice about it. Age related issue avoidance mainly but there is something to admire in having a vintage speaker with all original drivers. Unless the tweeter is an SL2000!Post edited by Emlyn on
I found out that proteolytic enzymes are not a good component in whatever doping materials we use (lol), and gamma radiation (a la Bruce Banner) are also to be avoided.
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Guess you'll be ok as long as you don't run a full-body scan on those 7's.Don't take experimental gene therapies from known eugenicists.
Another issue with replacing the Peerless with the RD0194 is the tweeter face plates are different sizes and the speaker bezel would need to be modified.Stan
Main 2ch:
HT:
Other stuff:
I'm not sure if this is about replacing a Peerless with an RD0194 or if it is about choosing between a Monitor 7 that came with Peerless over one that came with SL2000, modded to RD0. As far as swapping the tweeters goes, a lot of the Thiele Small Parameters between the two are quite different. Qts, Qms, Qes and Le are Iower in the Peerless. I suppose the two key ones would be the impedance and sensitivity graphs. Impedance is definitely higher in the Peerless KO10DT.George / NJ
iFi nano iDSD DAC
iPurifier3
Or just run the RDO bezel on a mill to trim. BTDTDon't take experimental gene therapies from known eugenicists. -
I have both and (to my old ears) they both sound fine. I think the Peerless tweet has acquired a sort of "celebrity status" over time. Having said that, I have never touched my Monitor 4's (not even to rebuild the XO)...and probably never will.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
For the record I’m not wanting to replace peerless with RDO’s, I wouldn’t even think about that. Was just a general question about which one someone likes better of the two models, and why. Second question was just a last minute thought as I have not tried sourcing peerless teeters..
Don't think youd go wrong either way pending the RDOs had a set of billet plates.Don't take experimental gene therapies from known eugenicists.
I would like to know too and it will be super helpful for someone who has the equipment (hint) to do comparison testing between the two, under identical testing procedures. FWIW this is the anechoic frequency response of the KO10DT Peerless tweeter (from the back of a NOS packaging box), which is of course without the "aperture tuning" hole that Polk modified them with. Shows a 5dB peak around 14kHz. This is also tested in an IEC baffle (I would assume) because they say Mounting: Wall.
George / NJ
iFi nano iDSD DAC
iPurifier3
