Monitor 7 RDO 194 vs Monitor 7B Peerless
If you were going to choose?
Why?
Can a person still get peerless tweeters?
    pitdogg2 Posts: 27,211
    They (Peerless) seem to be getting harder to get and in rougher shape than years past.
    xschop Posts: 5,331
    The original silk domes are comprised of a protein that deteriorates over long periods.
  • Emlyn
    Emlyn Posts: 4,804
    edited January 2023
    If the Peerless tweeters were original to the Monitor 7s and still worked fine I'd think twice about replacing them. Any other situation and I'd use the RD0 tweeters and wouldn't think twice about it. Age related issue avoidance mainly but there is something to admire in having a vintage speaker with all original drivers. Unless the tweeter is an SL2000!
    Post edited by Emlyn on
  • Gardenstater
    Gardenstater Posts: 4,799
    xschop wrote: »
    I found out that proteolytic enzymes are not a good component in whatever doping materials we use (lol), and gamma radiation (a la Bruce Banner) are also to be avoided.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,331
    Guess you'll be ok as long as you don't run a full-body scan on those 7's.
  • skrol
    skrol Posts: 3,456
    Another issue with replacing the Peerless with the RD0194 is the tweeter face plates are different sizes and the speaker bezel would need to be modified.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Gardenstater
    edited January 2023
    I'm not sure if this is about replacing a Peerless with an RD0194 or if it is about choosing between a Monitor 7 that came with Peerless over one that came with SL2000, modded to RD0. As far as swapping the tweeters goes, a lot of the Thiele Small Parameters between the two are quite different. Qts, Qms, Qes and Le are Iower in the Peerless. I suppose the two key ones would be the impedance and sensitivity graphs. Impedance is definitely higher in the Peerless KO10DT.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,331
    skrol wrote: »
    Or just run the RDO bezel on a mill to trim. BTDT
  • StantonZ
    StantonZ Posts: 452
    I have both and (to my old ears) they both sound fine. I think the Peerless tweet has acquired a sort of "celebrity status" over time. Having said that, I have never touched my Monitor 4's (not even to rebuild the XO)...and probably never will.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
    Toolfan66 Posts: 18,149
    edited January 2023
    For the record I’m not wanting to replace peerless with RDO’s, I wouldn’t even think about that. Was just a general question about which one someone likes better of the two models, and why. Second question was just a last minute thought as I have not tried sourcing peerless teeters..
    xschop Posts: 5,331
    Don't think youd go wrong either way pending the RDOs had a set of billet plates.
  • Gardenstater
    I would like to know too and it will be super helpful for someone who has the equipment (hint) to do comparison testing between the two, under identical testing procedures. FWIW this is the anechoic frequency response of the KO10DT Peerless tweeter (from the back of a NOS packaging box), which is of course without the "aperture tuning" hole that Polk modified them with. Shows a 5dB peak around 14kHz. This is also tested in an IEC baffle (I would assume) because they say Mounting: Wall.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
